Rod Bearing Part Number
Old Jan 2, 2005 | 07:07 PM
projectegr's Avatar
Default Rod Bearing Part Number
just to see if someone knows it offhand before I call Acura tomorrow. The engine is a b18c1 in a 1994 Integra GSR 4-dr 5spd. I just need the part number on the set of rod bearings.
Also I wanted to call Honda to see if they could get that part # seeing as honda is 30 miles closer than Acura to me.
jD
Old Jan 2, 2005 | 08:13 PM
shorto85's Avatar
Default Re: Rod Bearing Part Number (projectegr)
Did you have it measured so you get the correct bearings?
This article will also be very helpful...
http://www.boosted-hybrid.com/viewtopic.php?t=326
Old Jan 2, 2005 | 08:28 PM
kuja's Avatar
Do you know what color? Anyways, here.
Old Jan 2, 2005 | 09:12 PM
IN VTEC's Avatar
Maybe this will be a little easier to read.
Connecting Rod Bearing (1321x-P72-003)
A = 1 = Blue 13211-P72-003 (thickest)
B = 2 = Black 13212-P72-003
C = 3 = Brown 13213-P72-003
D = 4 = Green 13214-P72-003
E = 5 = Yellow 13215-P72-003
F = 6 = Pink 13216-P72-003
G = 7 = Red 13217-P72-003 (thinnest)
Old Jan 2, 2005 | 11:54 PM
s2kkid's Avatar
Default Re: Rod Bearing Part Number (IN VTEC)
I have a question on these bearings my self.
I have a stock crank and did not cut it, it is not needed.
My current bearings consist of:
Rods are like green and brown.
The mains have greens, brown, and a yellow.
Being that im still using a stock crank, can I get the ACL bearing kit, which has All Greens?
How much is the difference between these colors, and will it be in service limits?
Old Jan 3, 2005 | 04:42 AM
IN VTEC's Avatar
Default Re: Rod Bearing Part Number (vtecluder97)
If the crank hasn't been cut, you should always fall under the service limit. You still have to double-check by mic'ing everything or at the very least with plastigage.
Old Jan 3, 2005 | 06:07 AM
s2kkid's Avatar
where can i get plasti-guage from?
Old Jan 3, 2005 | 08:23 AM
IN VTEC's Avatar
I think the ACL bearing kits come with a small strip of green plastigage.
You can always buy more from Napa or Autozone in individual strips, made by Clevite. They're $.99 a strip. You'll want green plastigage. The red can be used for the cam journal clearance, but otherwise it would be more applicable to a small-block Chevy's looser main and rod bearing clearances.
Old Jan 3, 2005 | 10:36 AM
rastropovitch
Guest
Posts: n/a
ttt
Old Jan 11, 2005 | 11:39 AM
projectegr's Avatar
Default Re: Rod Bearing Part Number (MSchu)
thanks guys for all the info.
3c 3c 3c 2b
6 brown, 2 yellows
got them installed, no more death knock.
boydsc33
Mar 1, 2011 03:27 PM
truKalypso
May 18, 2010 11:29 AM
TurboKneeGrow
Mar 18, 2008 07:22 PM
hawkins1320
Aug 4, 2006 06:14 PM
chadwick16
Jan 31, 2005 04:21 PM
