something wrong with my car. help please
Old Jan 2, 2005 | 05:41 PM
Keewun's Avatar
Default something wrong with my car. help please
when i drive my car. My car sometime CHOKE specially when i step on it and it don't go anywhere, but when I slowly step on it. Somtime it goes smoothly as normal. IT IS MY CLUTCH DYIN OUT? or something else? because my axle boot is leakin grease out too. help please.
Old Jan 2, 2005 | 07:00 PM
The Internet Tough Guy's Avatar
Default Re: something wrong with my car. help please (EG2SnailLike)
sounds like you just need a tune up. how many miles / what car / what engine / any recent maintenance you've done would help.
clean air filter
get some new spark plugs.
change distributor cap and rotor
check valve lash
clean throttle body and iacv
check throttle cable tension
try some of that fuel injector cleaner
if your clutch is dying, your engine will rev up quickly when you're on the throttle but you won't go anywhere. the easiest way to check for that is go up a hill, put it in 5th or 4th and stomp on it. if your engine just pulls slowly (like it should) then everything's fine. if it keeps reving up and down change your clutch.
the cv boot leaking grease will bite you in the *** eventually. change it as soon as you can. but that shouldn't have any effect on your engine's performance. it will just click when you turn at low speeds.
Old Jan 7, 2005 | 08:12 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2SnailLike &raquo;</TD></TR><TR><TD CLASS="quote">when i drive my car. My car sometime CHOKE specially when i step on it and it don't go anywhere, but when I slowly step on it. Somtime it goes smoothly as normal. IT IS MY CLUTCH DYIN OUT? or something else? because my axle boot is leakin grease out too. help please.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2SnailLike &raquo;</TD></TR><TR><TD CLASS="quote">i have a stock del sol about 95k+ and drove it back home, it was runnin fine until my brother drove it and came back and told me about it. Everytime when I drive it my 2nd,3rd,etc. gear won't accelerate, except my 1st. i was wonderin' what's wrong with it.... COULD IT be my tranny? or something else? please help.</TD></TR></TABLE>
take it to your local auto mechanic.
Old Jan 7, 2005 | 08:59 AM
gt30typer's Avatar
Default Re: something wrong with my car. help please (DelSolSiR)
Probably needs a tune up , cap, rotor, plugs, fuel filter,
NO more ARCO
could be if you were messing around with your TPS but probably not
Old Jan 7, 2005 | 09:28 AM
SirRevvs's Avatar
Default Re: something wrong with my car. help please (gt30typer)
Fouled plugs? or maybe cap and rotor? Possible clogged fuel filter? if you don't know how to work on it yourself buy a chilton manual or take it to a mechanic.
Old Jan 7, 2005 | 09:30 AM
bsixteen's Avatar
my car bogged horrible after like 2k rpms. gutted my cat and it ran fine.
93integ_hatch
20
May 10, 2009 04:41 PM
zach1288
18
Mar 2, 2009 07:48 PM
BDRphaSe2
Aug 7, 2005 07:04 AM
21tgs
Jan 30, 2005 05:29 AM
