Another sway bar ????????
Old Jan 2, 2005 | 03:49 PM
Turbowa's Avatar
Default Another sway bar ????????
I did surch but after 9 pages still didn't find the answer I was needing. I now the CL and TL type-s sway bars are bigger then our stock ones and bolt right up. BUT are the standard CL and TL sways any bigger then are stock or is it just the type-s ones that are bigger?
The reason I ask this is because I found a set of TL/CL sways for really cheap and if there bigger I'll get them. If not hten I will keep looking for the type-s ones.
Old Jan 2, 2005 | 05:13 PM
syclone's Avatar
Default Re: Another sway bar ???????? (Turbowa)
they're different.. (rear) the regular cl/tl are 15mm, the type-s models are 19mm
the front swaybars are the same size for all models..
Old Jan 2, 2005 | 06:03 PM
Turbowa's Avatar
Default Re: Another sway bar ???????? (syclone)
So the front sway bars are the same on the TL/CL and TL/CL type-s, but bigger then the accord. And the rear on the TL/CL is slightly bigger then the one on the accord. But the TL/CL type-s is alot bigger tehn our stock one correct?
Old Jan 2, 2005 | 06:33 PM
syclone's Avatar
yeah.. i think the front is 1mm bigger on the tl/cl's.. accord's run 26.5mm while tl/cl's run 27.?mm
the rear, the accords are bigger at 16mm for the sedan and 17mm for the coupes..
i would leave the front alone with the stock one and just purchase the rear tl-s bar. upgrading the front and rear will reduce roll but maintain the same cornering characteristics.. increasing just the rear bar will reduce some understeer and improve handling to some extent..
Old Jan 3, 2005 | 04:39 AM
Turbowa's Avatar
Thanks, I justed checked and I think its for the TL type-s. It said the bar was 18mm. So that would be an increase over my stock. Not looking for much just a little. The guy is selling them as a set I was planning on only doing the rear and probably selling the front off.
Chrisfball12
Aug 24, 2008 10:22 PM
honda93
Jul 3, 2005 04:53 PM
SuNDaY DRiVeR
Jul 9, 2004 01:05 AM
azian21485
Jun 8, 2003 10:24 PM
Raocorp
Feb 4, 2003 03:04 PM
