Alternator keeps breaking... (searched)
Old Jan 2, 2005 | 02:29 PM
stRodda's Avatar
Default Alternator keeps breaking... (searched)
i just put in my 3rd alternator within the past year. can they be over revved and broken that way? when i had the swap done the accord pulleys were put on so i could use the belt i already had. earlier in '04 i put a new accord alternator in, since the pulleys match... but since then theyve broken 3 times. could they be internally falling apart or failing because im revving 2k higher than the car it was intended for? or are the alternators the same except for the ribs on the pulley?
Old Jan 2, 2005 | 03:32 PM
Mr.Dew's Avatar
Yep, it's Eric.
Default Re: Alternator keeps breaking... (stRodda)
why do you keep buying the accord alternator if it keeps breaking? Just buy the one that's designed for the engine next time btw.. what motor are you talking about anyways?
Old Jan 2, 2005 | 04:21 PM
stRodda's Avatar
Default Re: Alternator keeps breaking... (oNeMoBB1)
oh, sorry. i have a 93 h22 in my accord. i keep getting the same alternator, cause replacement is free. but i was just wondering if there is a difference between an accord and prelude alternator... other than the pulley.
Old Jan 2, 2005 | 06:12 PM
BrokeLude's Avatar
Is something physically breaking, or does it just quit charging?
Old Jan 2, 2005 | 09:23 PM
stRodda's Avatar
Default Re: Alternator keeps breaking... (BrokeLude)
it just quits charging. but i know theyre arent supposed to be replaced 3 times a year... so something is definetly wrong. nothing has ever physically broken.
Old Jan 2, 2005 | 09:31 PM
BrokeLude's Avatar
OK, the problem is most likely somewhere else in your electrical system, and it fries your alternator. Take it to an electrical shop, not a regular mechanic.
Same thing happened to me a while back. After 2 alternators, took it in and the guy had it fixed in 20 minutes. Cost me like $30.
Old Jan 2, 2005 | 09:40 PM
stRodda's Avatar
ok thanks man.
just wondering, is there an auto electric chain of stores out there? i dont know of any... im used to just going to a mechanic for any problem i had. do you happen to know what the problem ended up being with yours.
Old Jan 2, 2005 | 09:54 PM
BrokeLude's Avatar
Mine has an intermittent short somewhere.
As for the shop, I don't know of any chain, but the phonebook should have a bunch of shops. I think they would be under "automotive electrical" or something to that effect.
Old Jan 2, 2005 | 10:02 PM
precord96's Avatar
I had the same problems before. I went through about 4 alternators before I found a used oem alternator from HT, no problems since. It's the cheap remanufactured units that cant handle the revs. I would record the voltage on my rev/speed meter and the thing would quit charging around 7k rpms. Try and find a prelude or an oem one.
Old Jan 2, 2005 | 10:09 PM
stRodda's Avatar
Default Re: Alternator keeps breaking... (precord96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precord96 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problems before. I went through about 4 alternators before I found a used oem alternator from HT, no problems since. It's the cheap remanufactured units that cant handle the revs. I would record the voltage on my rev/speed meter and the thing would quit charging around 7k rpms. Try and find a prelude or an oem one.</TD></TR></TABLE>
ok, sounds good. thats what i was thinking, but i didnt know if it was just nonsense that i made up. and yea, im using a remanufactured one from autolite.
Old Jan 3, 2005 | 08:17 AM
brad_prelude's Avatar
is your car turbo?my lude is and i had the same problem till i got a heat shield made up
Old Jan 3, 2005 | 12:42 PM
stRodda's Avatar
Default Re: Alternator keeps breaking... (brad_prelude)
no, n/a... if it happens again, im just going to cal customer service and have them contact the store to get mea refund. then ill go find myself a oem prelude alternator.
aamccarty
Feb 22, 2017 08:01 AM
nanodc2
Nov 21, 2014 11:01 PM
flarinpnoi
Nov 20, 2006 12:54 PM
Polish_dude
Sep 11, 2006 06:37 PM
