type r front brace
does anyone have a pic of the upper brace and where it goes ? i have a eg and i have a type r brace
Those 2 holes on each side don't have to be drilled out on EG's. You can pop them out. They're little rubber plugs. Use 2 12mm bolts and nuts on each side to bolt the bitch down. Have to put the bolt through fron underneath (inside wheelwell) and use the nut at the top. Best bolts to use are the flywheel bolts (12mm) with the nuts that hold the intake or exhaust manifold onto the head. They fit perfectly.
OK I Finally have it
are you talking about the bar that is right behind the engine, Lower area Connects to the subframe Right near the Steering rack? One sides bolts has a bracket that holds one of the hoses going to the steering rack?
That HAS to be it.
That HAS to be it.
That HAS to be it.
That HAS to be it.
do u hve a pic of that bar
does anyone havea pic of unde the car on font of eng?
i hAVE APIC OF my bar but my site is down so cnt post i can email pic
emaIL me tooqwik1@aol.com
Go to this thread:
https://honda-tech.com/zerothread?id=108831
Scroll down to the pic of EP's m00gen m0bile with the front bumper removed. Below the headlights, spanning the radiator, a bar is visible.
HTH,
Reid
HTH,
Reid
wtf are you talking about
