Appropriate Rim size vs. weight
Old Jan 2, 2005 | 11:13 AM
mikey1987's Avatar
Default Appropriate Rim size vs. weight
the stock 15'' wheels on an integra weigh ~15lbs i believe.
would 16's make for a better drive?
Some 16' Rota Circuit's would weigh like 15 lbs each vs. the stock rim weight of 15 lbs for the 15' stock rims.
would the up to a 16 inch rim make for better track times and/or handling?
BTW i was conisdering Enkei rims before i found out that those suckers weigh up to 28lbs!
Old Jan 2, 2005 | 01:06 PM
ProjectDarkBlack's Avatar
Default Re: Appropriate Rim size vs. weight (mikey1987)
konig heliums are really light fvor their price i think 17`s are 15 lbs
Old Jan 2, 2005 | 01:54 PM
integra714's Avatar
Default Re: Appropriate Rim size vs. weight (ProjectDarkBlack)
i believe the bigger rims you have the slower you go because it takes longer for the tire to turn correct me if I am wrong
Old Jan 2, 2005 | 03:38 PM
TunerN00b's Avatar
Default Re: Appropriate Rim size vs. weight (integra714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra714 &raquo;</TD></TR><TR><TD CLASS="quote">i believe the bigger rims you have the slower you go because it takes longer for the tire to turn correct me if I am wrong</TD></TR></TABLE>
Um, no. Wheel and tire together determine the total diameter.
195/55 15
205/45 16
205/40 17
Those will all give you very close to the same diameter. If you keep the diameter the same, only the weight difference will effect acceleration.
Old Jan 2, 2005 | 04:31 PM
GG-SquadDB's Avatar
Default Re: Appropriate Rim size vs. weight (TunerN00b)
If u want more grip for better track times I would go with a 15 or 16 inch rim that weighs less than 15 I have a 15" rim that weighs 12lbs...keep in mind that the larger the rim the lower the profile on the tire and makes for a less flexable sidewall which in turn equals less grip from launch and a more uncomfortable ride not to mention tire noise... If i were you I would stick with a lightweight 15 or 16 inch rim
HA0LEFIED
Nov 23, 2006 12:33 AM
beqa16v
Nov 6, 2006 09:08 AM
hu
Sep 26, 2005 11:08 PM
AllMotorITR
Dec 9, 2001 05:15 PM
