D series tranny or clutch problem?
Old Jan 1, 2005 | 08:54 PM
maxheat's Avatar
Default D series tranny or clutch problem?
i just bought a 93 Civic hatch that needs a new "Tranny" the guy said; so im about to buy a new transmission; because when i put it in neutral and slowly let off the clutch i hear a bad griding noise EVEN IN NEUTRAL. when putting the car on the flatbed i heard some griding noise when pushing the car back so im still guessing its the transmission. I tried to drive it by, of course, putting it in first gear but the car doesnt move and it sounds like the e-brake is up and your trying to drive. And i cant put it in 5th gear but all the other gears are fine soooo... is it the clutch or the transmission?
o and also when putting it in neutral and letting off the clutch its kinda like having it in gear and letting off the clutch with no gas... the engine is about to cut off
Old Jan 1, 2005 | 09:19 PM
maxheat's Avatar
no1 knows?
Old Jan 1, 2005 | 10:31 PM
maxheat's Avatar
anyone?
Old Jan 1, 2005 | 10:35 PM
eK9aT10pSi's Avatar
Default Re: (maxheat)
it sounds like a throwout bearing. and/or the clutch disk or pressure plate is dead
Old Jan 1, 2005 | 10:47 PM
maxheat's Avatar
so its not the transmission?
Old Jan 2, 2005 | 12:12 AM
BatuKing's Avatar
no its the tranny. you moved the car while its in neutral and it makes a grinding noise right? it cannot be the throw out bearing.
Old Jan 2, 2005 | 12:17 AM
maxheat's Avatar
no no the car wont move when its in neutral but it makes a griding noise and the motor sounds like its about to cut off because im gettin off the clutch
Old Jan 2, 2005 | 12:23 AM
H22A EG6's Avatar
that is totally the tranny
Old Jan 2, 2005 | 01:26 AM
maxheat's Avatar
now ppl say its the tranny... i dont know what to buy now
Old Jan 2, 2005 | 05:51 AM
wacky96d16's Avatar
take the tranny off and buy a new used one they are cheap...
While it's off you can look at the bearing and the clutch plate.
You wouldn't buy something before taking it off anyways would you?
If you take it to a shop to get done, then ask the mechanic to SHOW you what needs to get bought before you buy anything. Rebuilding he tranny is going to be more expensive then buying one, so don't tell anyone to rebuild it unless you're doing some specific gearing or putting carbon syncros or something...
Old Jan 2, 2005 | 06:54 AM
nfinitecc's Avatar
Default Re: (wacky96d16)
werd i got a 98 ex tranny for 50 bux still work great going on a year now
Old Jan 2, 2005 | 06:57 AM
slambedcivic's Avatar
Default Re: (nfinitecc)
most likely broken spider gears in the differntial.
Old Jan 2, 2005 | 12:27 PM
maxheat's Avatar
too bad u live in texas eh nfinitecc =X
yea im about to take it off today or tomorrow and see whats the deal... im prolly gonna end up buying a new clutch and tranny but i dont want to spend that much money
Old Jan 5, 2005 | 01:35 PM
birdnuts6's Avatar
hey i am ineterested in that tranny..
bird
Old Jan 5, 2005 | 01:50 PM
snoochtodanooch's Avatar
Default Re: (birdnuts6)
yea i would agree with taking it off first or taking it to a mechanic. It "could" be the clutch disc being done and the metal rivets hitting the pressure plate, but i really think the trans is done. Start calling junkyards to grab a trans, they aren't very expesive, U-pull it places are even better. You do the work, and you save the money.
Old Jan 5, 2005 | 02:23 PM
maxheat's Avatar
yea i just bought another tranny...
its a 94 del sol SI tranny for $50 bucks. Only thing bad about it is that the guy said it pops outta 2nd gear during hard shifts but it will only be temperary untill i get money for full swap
eh2ner
Oct 7, 2008 12:59 PM
Chubz
May 30, 2005 08:32 AM
Chubz
May 30, 2005 06:33 AM
Jason C SBB
18
Feb 22, 2004 11:37 PM
DX187VTEC
Jan 31, 2003 12:28 AM
