K20 into Accord
Hey looking to put in a K20 in my accord. Is this possible, also will this be better then have the K24 or not. The problem with the K24 is that there are no boltons for my model(4dr/LX/Auto)
Pleas help me out and lemme know if you find any web sites with engines, looking for the K20 from a Type-R RSX
Thanks a lot.
Thanks a lot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote"> K20 head.
FLows 3542345 times better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K24Accord »</TD></TR><TR><TD CLASS="quote"> The accord is a 2003</TD></TR></TABLE>
The problem is going to be engine management. You'll need to make some sort of adapter harness to utilize an automatic RSX ECU and have it modified to run whatever combination you wind up with, like Type R or S head on your K24A so you don't give up the torque. The TSX engine would be a better choice actually, you would use the Accord or an Accord Euro R throttle body to eliminate the "drive by wire."
brian g
brian g
