cluster options
Well im redoing my whole interior on my ej and i want to change the cluster while im at it. I really want a 99 si cluster, will this dfit? If not can it be made to fit? And how hard would that be?
Thanks
Thanks
With enough work and time you can use any cluster that you want
I have an EK cluster in my EG. The wiring was a pain but I like how it looks. The only issue that I had was that the EG and EK cluster are shaped nearly opposite so I had to Dremel my bezel which right now does not look so hot but after some figerglass I think it will be ok.
from what i read the 99 si cluster will fit the ek, so im assuming it would take just about as much work then
How hard was the wiring and where did u find good diagrams?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">from what i read the 99 si cluster will fit the ek, so im assuming it would take just about as much work then
How hard was the wiring and where did u find good diagrams?</TD></TR></TABLE>
Of course the 99 si cluster will fit in any ek, it's an ek itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">It's an LS cluster, same thing except lower redline.</TD></TR></TABLE>
And doesn't say "Premium Unleaded Fuel Only". Anyways, an Integra cluster does not take long at all to repin. Takes me about 15-20 minutes. If you want to be different and don't mind the small gap at the top, go with the Integra. If you want an OEM fit, any EX, Si, LX, CRV, CTR, SiR, VTi, 1.6 EL cluster will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
And doesn't say "Premium Unleaded Fuel Only".</TD></TR></TABLE>
Just says "Unleaded Fuel Only" w00pty doo. Anywho, I'd love a CRV cluster, I like'm a lot.
andy8ass
Feb 8, 2013 01:23 AM
excaliberneon
Mar 31, 2004 02:26 PM
