What type of B18 Swap should i do?
Old Jan 1, 2005 | 12:53 PM
ted's Avatar
ted
Default What type of B18 Swap should i do?
hey i drive a 93 civic DX hatch and em going to get a engine swap soon. Im a daily driver and looking for some more fun. Im having a lot of trouble trying to decide on witch b18 swap i should go with. ?
#1) b18b ls $1800 and try to get a custom turbo kit to gether for cheep.?
#2) b18c1 gsr $3400 and do intake exhust and headers i would be happy with just that.(good power) ?
#3) B18C5 type r $ for $4500 about a $1000 more than the gsr not sure if its worth it bec i no a gsr would be good enuff ??
what do u think?
thank u
Old Jan 1, 2005 | 12:55 PM
RTE117's Avatar
Default Re: What type of B18 Swap should i do? (ted)
LS turbo.
Old Jan 1, 2005 | 01:47 PM
runvsofkris's Avatar
Default Re: What type of B18 Swap should i do? (IDriveAHonda)
umm LS/vtec.....
Old Jan 1, 2005 | 01:52 PM
ian.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda &raquo;</TD></TR><TR><TD CLASS="quote">LS turbo. </TD></TR></TABLE>
Old Jan 1, 2005 | 01:54 PM
caonima's Avatar
Default Re: What type of B18 Swap should i do? (IC33)
whats the advantages of LS engine over a b18c5
Old Jan 1, 2005 | 01:59 PM
RTE117's Avatar
Default Re: What type of B18 Swap should i do? (caonima)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caonima &raquo;</TD></TR><TR><TD CLASS="quote">whats the advantages of LS engine over a b18c5</TD></TR></TABLE>
The thousands you'll save.
If you look around and shop wisely you can probably put together a decent LS turbo setup for the price of a B18C5 swap.
I used to have a GS-R 6G Civic.. Loved it to death but it was an absolute coke habit if you know what I mean. I might mod my 2000 EX daily driver for some fun.. Going D16 turbo. 200+ whp and gobs of torque for way less.
Old Jan 1, 2005 | 02:36 PM
Eyes Only's Avatar
Ls turbo
Old Jan 1, 2005 | 02:50 PM
japspecnegro's Avatar
Default Re: What type of B18 Swap should i do? (The Pastor)
I love Type-R's but at the point of sale i would do LS on Boost
Old Jan 1, 2005 | 03:28 PM
Maverik4k's Avatar
Default Re: What type of B18 Swap should i do? (japspecnegro)
b16 turbo or ls turbo
Old Jan 1, 2005 | 03:29 PM
ek9800's Avatar
Default Re: What type of B18 Swap should i do? (Maverik4k)
N/A- Type-r
Boost- LS
Old Jan 1, 2005 | 03:52 PM
ted's Avatar
ted
if i go with a ls and than turbo it would u recommed staying with the ls trany or swith it for a gsr or some thing??? thanks every one!!!
Old Jan 1, 2005 | 03:54 PM
JSPECHB's Avatar
Default Re: (ted)
B16T
Old Jan 9, 2005 | 10:10 AM
Judd's Avatar
Default Re: (JSPECHB)
theres nothing better then running decently fast n/a against a boosted car... boost just comess with to many problems that might and might not happen but ill keep with the n/a fooo life maybe
Old Jan 9, 2005 | 10:14 AM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ted &raquo;</TD></TR><TR><TD CLASS="quote">
You can find a b18b swap for alot less than that.... look around the classifieds.
Old Jan 9, 2005 | 10:18 AM
Judd's Avatar
Default Re: What type of B18 Swap should i do? (cnyej1)
if you want a decently fast motor in your hatch then go usdm b18c1 or the jdm sir-g (jdm gsr) if you want a fast motor in your hatch then go usdm b18c5 or the jdm b18c(jdm type r) if you wanna have your car strait as a racecar then go b18c1 turbo but problems are gonna catch up to you and it wont be worth it in the end unless you have a daily driver
Old Jan 9, 2005 | 10:20 AM
Judd's Avatar
Default Re: What type of B18 Swap should i do? (Judd)
dont mess around with the ls unless your on a tight tight budget, if you are then save cause itll be worth it in the end trust me... the LS in a hatch isnt all that fast of a motor you know maybe a high 14 or something... b18c1 will run probly a low 14 on street tires and the type r will run a mid-high 13 on streets and a high 12 low 13 on slicks stock... hopefully this helps you out some
Old Jan 9, 2005 | 10:23 AM
2000EM1's Avatar
Old Jan 9, 2005 | 10:24 AM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">You can find a b18b swap for alot less than that.... look around the classifieds.</TD></TR></TABLE>
ya prob like 1k less, but id go ls turbo or n/a c5
Old Jan 9, 2005 | 10:26 AM
2000EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Judd &raquo;</TD></TR><TR><TD CLASS="quote">dont mess around with the ls unless your on a tight tight budget, if you are then save cause itll be worth it in the end trust me... the LS in a hatch isnt all that fast of a motor you know maybe a high 14 or something... b18c1 will run probly a low 14 on street tires and the type r will run a mid-high 13 on streets and a high 12 low 13 on slicks stock... hopefully this helps you out some</TD></TR></TABLE>
bah. Don't listen to this guy, he seems a bit biased against the LS. An LS with a turbo will cost roughly the same as an NA c1/c5 or JDM GSR/Spec R swap if you piece together your own turbo kit. You'll be faster in the end with an LS turbo than you would with any b18c NA.
Old Jan 12, 2005 | 03:48 PM
Gekko's Avatar
Default Re: What type of B18 Swap should i do? (2000EM1)
LS Turbo all the way, the money you save can go into building the block and what not.
Old Jan 12, 2005 | 05:27 PM
Judd's Avatar
Default Re: What type of B18 Swap should i do? (Gekko)
i have nothing against an LS ive just driven a couple ls hatches and its not all that impressive... if you go turbo in a ls itll be fast but you might as well go gsr or itr just to keep the stock motor and keep fast... do you what you want tho cause you know your gonna and thats your car
Old Jan 12, 2005 | 05:30 PM
boi_si's Avatar
Old Jan 12, 2005 | 05:32 PM
Nate047's Avatar
+1 for LS turbo...
Old Jan 12, 2005 | 05:47 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: What type of B18 Swap should i do? (Nate047)
if you got that money go ls/vtec or b20/vtec and get ctr cams and some cam gears, gsr or b16 trans, a nice clutch, a nice header, and exhaust. you'll have a nice daily driver with some power for the track too. It should set you in the mid 13's all day long.
Old Jan 12, 2005 | 05:52 PM
Del Sizzle's Avatar
Default Re: What type of B18 Swap should i do? (turbofienD 04)
LS/Vtec Turbo
