96 accord bumper fog lights
Old Jan 1, 2005 | 12:03 PM
i20ar's Avatar
Default 96 accord bumper fog lights (finshed w/ pix)
iv'e searched and searched but i cant find any really helpfull information on how excactly to convert my bumper blinker lights so they always stay on but they also blink or how to switch the functions of the bumper lights with the corner lights.. does any one know of a good write up on how to do this? if not can anyone explain to me how to do this i would really apreciate it.. thnx
Modified by 14aZnS at 4:37 PM 1/10/2005
Old Jan 1, 2005 | 12:57 PM
SlammedCD7's Avatar
Default Re: 96 accord bumper fog lights (14aZnS)
search, https://honda-tech.com/zerothread?id=211788
Old Jan 1, 2005 | 02:39 PM
i20ar's Avatar
Default Re: 96 accord bumper fog lights (Wylie15)
thnx ... was that post archived? i havent seen that one..btw do i need to take off my bumper to take the lights out? or how do i actually get to the socket
went to the junkyard today ... couldnt find the socket
Modified by 14aZnS at 4:00 PM 1/1/2005
Old Jan 1, 2005 | 03:48 PM
aZnAcCoRd02's Avatar
You need to find a turn signal harness from a 92-00 Civic and the socket as well(you can get the sockets at Honda). I just did this to mine......
the civic signal harness has 3 wires (red, black, and green)
Cut off some your Accord signal harness and leave enough so you can connect the new Civic harness
Connect the wires accordingly and youll notice you have an extra red wire.
Splice open the positive connections on your corner lights
Run and wire from those positive connections in your corner lights to your extra red wire on the new Civic turn signal harness.
If you want to read more check out this post
http://www.superhonda.com/foru....html
It should end up looking like this
Old Jan 1, 2005 | 07:26 PM
layzi3boi's Avatar
Default Re: 96 accord bumper fog lights (aZnAcCoRd02)
u don't really need to find a harnest. u can do this with 2 relay and speaker wires. it also make ur blinker faster.
Old Jan 1, 2005 | 07:27 PM
fw190bvi's Avatar
Default Re: 96 accord bumper fog lights (layzi3boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by layzi3boi &raquo;</TD></TR><TR><TD CLASS="quote">it also make ur blinker faster. </TD></TR></TABLE>
thats the electrical systmes way of telling you, your fellow motorists, and the police that your have a burnt out bulb/short in the wiring
Old Jan 1, 2005 | 10:11 PM
Carolina Fried Rice's Avatar
Default Re: 96 accord bumper fog lights (fw190bvi)
I want to do this also but I have the clear bumper lights (I know, I know) But anyone ever done this with the clear lights? If not I'll probably still try it.
Old Jan 2, 2005 | 05:23 AM
Default Re: 96 accord bumper fog lights (TSAF22B1)
i have clear bumper lights in mine
Old Jan 2, 2005 | 09:35 AM
i20ar's Avatar
will the clear lenses melt?.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnAcCoRd02 &raquo;</TD></TR><TR><TD CLASS="quote">You need to find a turn signal harness from a 92-00 Civic and the socket as well(you can get the sockets at Honda). </TD></TR></TABLE>
i can use any turn signal from 92 -00 civic? from what i found i thouht it was 92-95? or i can use any one?
also Im going to get the parts from the junkyard so what do excactly need... just the turn signals in the corners and the bulb that comes with it?
Old Jan 2, 2005 | 09:55 AM
Mine havent melted, and im sure it isnt supposed to
Oh yeah it is just a 92-95 Civic that I got mine off of
You need the the wires with the connector on the end
You need the socket that you plug the connector too
The bulbs type will be 1157
Old Jan 2, 2005 | 10:11 AM
i20ar's Avatar
haha sry but i just want to make sure i got this so when i go to the yard can i..
take out the corner from a civic and pull out the socket with the bulb and cut the wires...
Old Jan 2, 2005 | 01:47 PM
its all good, yeah bulb, socket, connector, and wires, you need all those to do this mod
Old Jan 2, 2005 | 01:51 PM
i20ar's Avatar
COol so thats it?! awsome.. well since i know what parts to get i just need to find them.
as for my other questin how to i get the bumper lights out?
Old Jan 2, 2005 | 04:47 PM
u need a flathead screwdriver and a good eye ahha....
if you look on your lower grill look towards your bumper light and youll see a screw in there, just unscrew that and it comes right out....its a challenge gettin it back in but with time and persistence youll get it, usually takes me a few tries.....theres a little metal clip that is supposed to stay covering the hole (its on the body) youll see it when u remove the bumper lense....lose that and your screw doesnt stay in tight and could lead to your light falling out!
good luck any questions just keep replyin lol
Old Jan 2, 2005 | 09:45 PM
I got home from work tonight and decided to attempt the "bumper light trick". I just happen to have a junk civic in my yard so I used the civic corner harness and followed aZnAcCoRd02's directions. ( &lt;-Thanks man!) It took about an hour to complete. Very easy mod (if you have any wiring experience at all). Heres some results. Again, I have the clear front lenses... but it came out ok.
HT kicks ***.
Old Jan 2, 2005 | 09:57 PM
i20ar's Avatar
LuCky! .. i just need to find the harnes's.... i couldnt belive the junkyard didnt have any civics 93-up... kinda scary
Old Jan 3, 2005 | 10:42 AM
fw190bvi's Avatar
i know this is a bit OT....but since were talking about stock lights and such.....
last night when driving a buddy home ii noticed hi and low beams come from the same housing......or at least i could swear it seemed that way.....what do the center lights of the headloght do....CD's have 2 housings, the outer of which is a dual filament, high and low, correct??...then what is the middle?....and secondly, there are 2 bulbs in each, corner correct?
Old Jan 3, 2005 | 12:02 PM
i20ar's Avatar
The highs and low do not come from the same housing... the housings on the inside are your high beams... next time get out of your car and check youll see .. the high beams dont have a cover over them so when you look throught the lense you should see just the bulb... and yea the corners have to bulbs.
lol... since you got me o/t with the lights yesterday my aunt parked next to mar car and she has an acura tl... and it almost looks exactly the same as my 96.. do they have the same headlights?
Old Jan 3, 2005 | 12:03 PM
fw190bvi's Avatar
not neccesarily the same, but they are pretty much the exact came car
Old Jan 3, 2005 | 06:20 PM
i20ar's Avatar
so the head lights arent the same demensions.. becuase i was wonder if i could put those headlights on my car when i looked they looked about the same size ..
Old Jan 8, 2005 | 05:02 PM
i20ar's Avatar
HEY GUYS!
Thanx for all the help i got the lights hooked up they looked great.. the hardest part was finding the harneses... at The first place i actually found them the guys wanted to chage me 40$ i was like no way... so i found some other junkyard and i found them myself.. all they charged was 5$!! what a steal.. so if your out there make sure you price around so you dont get riped off.. thanks a lot tho Every1...
Old Jan 8, 2005 | 05:42 PM
posta pic!!
Old Jan 8, 2005 | 06:16 PM
i20ar's Avatar
yea ill try to get sum up asap.. ill try tonight
Old Jan 10, 2005 | 03:32 PM
i20ar's Avatar
HEy gUYs here usm pix so sorry for the bad quality couldnt find the digi cam so i had to use the video camra as a still camera + it was raining so made things look wierd but heres the finished product
heres the links to the full sizes if you want... sry for poor quality
front
right
left
front w/o lights
Old Jan 10, 2005 | 06:35 PM
i20ar's Avatar
wat u guys think? ... oh yea i buaght the amber colord bulbs.. there "sylvania 1157all" bulbs will they melt my lenses? its says "OEM" on the box....
