help with identifying name of this sensor..
hey i need to know what to call this sensor because im gonna run to autozone and see how much they cost. its the towards the top of the hood on the throttle body. my idle is all screwy and that seems to be the problem. if anyone knows the approx. costs right off hand that would be great too. thanks.
The one on top of the throttle body is the map sensor but I dont think thats your problem. Your problem might be the TPS sensor which is on the back side towards the firewall of your car. Dont know how much it costs new either
no sir. checked 3 times now. unless there is sumthing i missed SOMEHOW but i doubt i could of. we did an engine replacement, the engine ran fine in donor car, but we used non running cars tb cause the other engine didnthave it. so i figure that may be the problem
ok i found some more info thanks for the help im gonna try tightening that screw tommorow and if that doesnt work im gonna scrape up some cash for carb cleaner
to being unemployed
to being unemployed
idle problem is better but not fixed. how far do i screw the fitv in? i screwed it until i could see those holes on the inside. i didnt want to force it. but now it idles from 1k to 1.5 k vs the 1k-2k its barely noticeable. i cleaned the screen on the iacv too. im gonna put a new tb gasket in and see if the problem will get solved
ok ima try that tommorow then and see if the problem is all the way solved. because now that i kicked my muffler off for being gay yesterday its super loud and noticeable.
Jakester9500
Nov 19, 2008 07:10 AM
deucedeuceEK
Apr 27, 2007 02:39 PM
comptechgsr2000
May 8, 2002 03:53 PM
