b18 swap into eg ???
I have a eg with a 00ls motor and a JDM p75 ecu. It drives fine but I just noticed after driving in 3-8" water on the freeway up here in ohio for the last 4 days that the oil press sender , 2wire coolant senser( under the distibutor) and the speedo senser were all disconected. now I got just as good gas milage as before and the only code it through was the speed senser, Is there a reason why that was the only code thrown, I would think that the other sensers are just important and they should have thrown a code.. Is it that it is a JDM ecu.
any ideas
thanks
any ideas
thanks
i have a b18 swap in a eg and am throwing the same sensor. code 17 right? so its not the speed sensor. i havent really drove my car yet cause i decited to go ls/vtec. dut i hope i can take care of this problem. thank you
Dee_333
Jun 8, 2011 10:05 PM
ringgold
Oct 2, 2004 05:49 PM
