Turbo GSR?
I know this is not the correct forum but it would not let me post in the Turbo forum for some odd reason? Anyways, I was just curious about boosting a GSR? I have about 110k miles on my GSR, is it not good to boost an engine w/ that many miles? Will the stock axels be sufficient for the increased HP? How much does a turbo setup cost? Just curious, that is all. Thanks.
search search SEARCH
you can boost a gsr with high miles just do a compression test.....
stock axles are fine depending how much HP you want
If you have to ask how much it costs, you cant afford it
with new parts ~$3000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWEETDUDE »</TD></TR><TR><TD CLASS="quote">Pocket change biotch! Cuz im Rick James!
Thanks.</TD></TR></TABLE>
LOL
Thanks.</TD></TR></TABLE> LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fleasme428 »</TD></TR><TR><TD CLASS="quote">Hp dosnt break axles, its torque rating u have to look into when bying axles...</TD></TR></TABLE>
True. I guess that is misleading. With a turbo B18c1 usually when you have a certain HP number your TQ falls with a specific range. With a basic turbo set-up his axles will be fine.
