lsvtec with different configuration
Old Jan 1, 2005 | 09:19 AM
99lsvtecauto's Avatar
Default lsvtec with different configuration
i have a lsvtec know
But its starting to get on my nerves
RIGHT NOW i have b18b/b16a2
I want to know if i take b18c1 block/ b16 head / ls crank what else would i need to complete the motor i am reusing my ls crank and rod .
I AM AWARE THIS IS SIMILAR TO A POORMAN R BUT a using a ls crank to keep my lsvtec and get rid of leaking oil line, and head gasket which were all new
Old Jan 1, 2005 | 10:41 AM
Plugs's Avatar
Default Re: lsvtec with different configuration (99lsvtecauto)
Old Jan 2, 2005 | 04:24 AM
Default Re: lsvtec with different configuration (ickabod)
i just want to use a gsr block with b16 head instead of a ls block . i am still want 2 use the ls crank, and rods but use the gsr block4 the girdle , main caps, oil squirters etc i had a ge girdle that would not work on my lsvtec once already so i want to try lsvtec a different way
Old Jan 2, 2005 | 12:03 PM
delslow94's Avatar
its been done many times before and will work. all u need is your crank and rods then whatever pistons you want. ull be fine.
Old Jan 3, 2005 | 04:35 AM
Default Re: lsvtec with different configuration (delslow94)
that's what i thought when i was searching no 1 really had a configuration like that my crank and rods are fine . i know i'll need new rings
Woody.
53
Feb 11, 2011 02:06 PM
jordan2305
Dec 11, 2007 04:47 PM
1heavy4dr
Jul 26, 2005 05:26 PM
JDMlyfestyle
Sep 27, 2004 02:06 AM
Nextelbuddy
11
Jun 4, 2003 03:11 PM
