The real deal on fitting 225's on 3rd gen Integras?
There's a lot of mixed reviews about 225's fitting on 3rd gen tegs. I'm wondering what, if anything, needs to be done to fit 15X7 wheels with 225/50 tires onto the front of an Integra. Spacers needed? What offsets work? Need to roll the fenders?
Stock height, or can it be lowered? If so, how much has worked for you guys?Thanks
eesh, that's a hard one. I was running 215/40/16's on my teg and at full lock, I would rub on the chassis. I bet with a little bit of a spacer, I would have been able to pull of a 225. So, I'd have to say that depending on your offset combined with a little bit of a fender roll and no fender liner, you'd be able to pull it off. Good luck
edit: Oh yeah, I was lowered about 2-2.5 inches at the time
But anyways, try it with stock ride height and see how it behaves, then lower accordingly.
caliprelude3087
Apr 24, 2005 12:59 AM
