d series motor turbo with ac???
Old Dec 31, 2004 | 07:57 PM
Slvr_CRX's Avatar
Default d series motor turbo with ac???
I have a 93 honda hb with a d series motor if i turbo it will i be able to keep my ac??? thanks for your help and happy new year
Old Dec 31, 2004 | 08:05 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: d series motor turbo with ac??? (Slvr_CRX)
check my sig.
my 92 hatch, i built my own manifold, and tunned it my self. SOHC's and TURBO's with AC can work...
Old Dec 31, 2004 | 08:06 PM
Street Ghost's Avatar
Depends on what manifold and downpipe. But yes, you can keep your AC, if you want. Just get a manifold and downpipe that won't interfere with your AC components.
Old Dec 31, 2004 | 08:20 PM
Built B16A's Avatar
Default Re: d series motor turbo with ac??? (_Edge.ONE)
im not sure what companys make AC friendly turbo kits. either way, im sure it'll cost more. their alot harder to create, and time consuming.
and usually... TURBO owners don't appreciate AC most of the time, since it takes up space, that could be used on larger IC piping, and DP diamater, and when on, really bogs down the engine.
Old Dec 31, 2004 | 08:39 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: d series motor turbo with ac??? (Built B16A)
does anyone here know if the apexi ball bearing turbo kit for the sohc A/C friendly? as well as the drag and revhard
Old Dec 31, 2004 | 10:42 PM
eK9aT10pSi's Avatar
Default Re: d series motor turbo with ac??? (BrokeAssPinoy)
yes, direct bolt on, no probs clearing the a/c. also the greddy kit clears a/c perfectly. ive had both and they work perfectly. no interferecnce
Old Jan 1, 2005 | 09:16 AM
Default Re: d series motor turbo with ac??? (eK9aT10pSi)
cool
Old Jan 1, 2005 | 10:00 AM
B16aDasher's Avatar
the greddy kit is a/c friendly
olddohc
Oct 5, 2017 09:12 AM
97ekjose
May 2, 2010 09:53 AM
delsolnewkid
Apr 1, 2006 06:12 AM
import810
Oct 23, 2005 09:01 AM
sxecustoms
Oct 18, 2003 09:29 PM
