still have negative camber after installing camber kit =/
i just finished installing the ingalls front camber kit. and after i installed it, i pulled the a-arm foward (to make positive camber). and when i dropped it back down, it looked the same as it was when i didn't have a camber kit...
do you think the bolt that tightens at the bottom of the camber kit got loose and the a-arm went back the way it was? please help!!!
chaaaaances are, you didnt adjust it right lol, just playing with ya.... i would take it to a NTB or something and get a full allignment, they'll adjust your camber as well and do it all for like 70 bucks... i mean but if you wanna go your own route thats cool too... i just dont like messing with stuff on my car when it comes to allignments, cuz thats one thing i dont know what the hell im doing... good luck
With the Ingall you need to take it to an alignment shop so they could fix the camber. Nothing you could do, i have the same kit.
was the camber suppose to be the same though? or you can notice it being positive just by adjusting it with your hands?
Did you get the full upper control arm or just the little bushing piece? If you adjust it all the way you should see some difference then it was. Alignment would tell you if it seen any difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">take it to firestone, 139 for lifetime alignment
Most (in my district) cannot align a lowered vehicle. If a car is too low, the front bumper blocks the sensors on the alignment heads that we use.
</TD></TR></TABLE>Most (in my district) cannot align a lowered vehicle. If a car is too low, the front bumper blocks the sensors on the alignment heads that we use.
