Seat modification
Hey fellas, I was wondering if the front and rear seats from a 99-00 civic Si will fit into a 93-95 civic ex coupe? Is there anything to make them fit or any modifactions I might have to do? Please let me know, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">front will fit perfect, rear u wont be able to close cause they have 40/60 split fold </TD></TR></TABLE>
umm if you call one bolt not lining up perfect,then yes it's perfect.
What you have to do is swap the the seats rails fron the eg and put them on the ek seats....It took me like 2hours to do the first seat..after I knew what I was doing the next seat took 30min
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">i thought ek's will line up w/ eg's like tegs?</TD></TR></TABLE>
I wish..it would have saved me alot of time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red97gst »</TD></TR><TR><TD CLASS="quote">
What you have to do is swap the the seats rails fron the eg and put them on the ek seats....It took me like 2hours to do the first seat..after I knew what I was doing the next seat took 30min </TD></TR></TABLE>
Well thanks for the information bro. So, since one bolt doesn't line up what did you do? Or did you just leave one bolt off?
You swap the rail. Very easy. For instance, my EJ8 seat rails bolted PERFECTLY to the del Sol seat. Even could use the plastic coverings for the seats. The way the rails bolt to the chassis differ a little, but the way they actually bolt to the seat is the same, which makes the process that much easier.
S1LENT94D00R
16
Jan 24, 2012 09:17 AM
