My tac is jumping, but no problems?
Old Dec 31, 2004 | 01:19 PM
technine's Avatar
Default My tac is jumping, but no problems?
I recently notice my tac stopped working all together this morning and this afternoon it started jumping around and finally settled and now works fine. What could this be? I had a bad ignitor in my civic and it jumped, but the car also bogged down when it did this so I don't know if it could be that.
I have a 98 cl 2.2 so it is basically an accord. Do I need to replace the ignitor or was it just a freak occurance? Also, my brake light comes on only in drive gears and not P or N (park and neutral on the automatic) and sometimes the ABS light comes on. All these problems started last night and the tac I noticed this morning so maybe they are related? HELP! TIA
Old Dec 31, 2004 | 03:45 PM
technine's Avatar
Default Re: My tac is jumping, but no problems? (technine)
anyone??
Old Jan 3, 2005 | 12:16 PM
technine's Avatar
Problem is now gone and I still don't know why it started. Maybe the rain got into some electronics??
Old Jan 3, 2005 | 01:43 PM
liquiid11's Avatar
I had the same problem(96 accord). I let it go, and it stopped working all together, causing the car to run bad. It is the speed sensor. You need to replace it. When it goes the check engine light will come on and it will effect the cars idling.
Old Jan 3, 2005 | 03:37 PM
technine's Avatar
Default Re: My tac is jumping, but no problems? (liquiid11)
But doesn't the speed sensor have to do with the speedometer?? I was having tacometer problems of it cutting in and out and also brake light and abs light probs. They have gone away completely for the past 2 days.
There was also no driveability problems what so ever. Wierd eh.
Old Jan 3, 2005 | 03:54 PM
liquiid11's Avatar
Thats what i though and was told by numerous mechanics, but i took my car to a perfomance place and the first thing they said, it is your speed sensor. i changed it and have had no problems yet.
Old Jan 4, 2005 | 12:26 PM
technine's Avatar
So when your car ran bad it was because it was in "limp-home-mode" check engine light was on??
Old Jan 5, 2005 | 08:57 AM
SearchBeforeUPost!'s Avatar
My tach was jumping around and replaced the ignitor with an old one I had sitting around. The jumping went away.
Old Jan 5, 2005 | 09:07 AM
Filthy Focker!'s Avatar
Default Re: My tac is jumping, but no problems? (SearchBeforeUPost!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquiid11 &raquo;</TD></TR><TR><TD CLASS="quote">Thats what i though and was told by numerous mechanics, but i took my car to a perfomance place and the first thing they said, it is your speed sensor. i changed it and have had no problems yet.</TD></TR></TABLE>
You are mistaken. Speed sensor has nothing to do with the tach.
Your ecm gets input for the engine speed via the crank position sensor (CPS). THe signal travels through the ICM. So it is possible that from the sensor all the way through the ecm, your electrical connection may be weak. Best thing to do is to inspect the connections and make sure they are not loose or contaminated with oil. THen if the problem returns and you get sick of it, you may need to test the voltage output of the CPS using a multimeter to see if indeed you are losing voltage at the ecm.
fs
Old Jan 5, 2005 | 10:14 AM
EX-JAY's Avatar
The problem, I am pretty sure, is your ignition coil. I had the same symptoms you are describing.
Old Jan 6, 2005 | 10:04 AM
Jago's Avatar
Default Re: My tac is jumping, but no problems? (EX-JAY)
it's the ignitor
Old Oct 18, 2005 | 04:14 PM
HomeDepotMade's Avatar
Default Re: My tac is jumping, but no problems? (Jago)
hey i have a simliar proble. my firends 96 accord speedo doesnt work. well it jumps around. like idles then jumpls to redlinw when he drive or reverses. so can anyone help a friend out? thanks
Old Oct 18, 2005 | 09:29 PM
momstaxi's Avatar
Default Re: My tac is jumping, but no problems? (Hype Vtec)
yes, it seems as if your ignition control module is going out, it is located inside the distributer...
mmorgan94
Sep 18, 2016 09:05 AM
platinum405
Aug 29, 2007 10:28 PM
ILOVEGIRLS
Jan 15, 2006 08:48 PM
maivietla
Feb 23, 2005 06:11 AM
brokencivic
Aug 4, 2004 08:55 AM
