2000 accord LX need some info.
I'm a Jackass
SO i got some people here at work wanting to go with forced induction. however, im only familiar with the EG and EF civics. my extend of knowledge isnt too braod when it comes to the accords so i need some info.
does the 2000 accord 4cyl come with e f22 motor?
its obviously OBD2, can you go to OBD1? do they sell a harness for the accord?
thanks again!
thanks again!
2000 Accords have a 2.3L, F23. They so make thurbo kits for it that will run safely on the stock motor. Check out turbokits.com for some of their kits. Best bet for good speed is a H22 swap. Bolts right up to the F23 tranny.
I'm a Jackass
so an H22 us a straigh bolt on???? nice!!! but can you go from OBD2 to OBD1 on these bad boys???
as far as the turbo kit i wanted to make amanifold for it and go that route. HMT baby!
Guest
Posts: n/a
Though the H22 is the common swap into the accord it isn't necessary. You can make more power with less money by simply bolting up a turbo to your F23 than if you swap in an H22. The great thing about the F series is they come stock already sleeved! You can push upwards of 260 whp reliably through stock internals for several years.
I'm a Jackass
well im sure my co worker would rather go turbo rather than swap a motor so im gonna see a bout the whole deal...would it matter if the F23 is a Ulev motor? or does that not matter?
anyway all i need is to source a turbo from the Jnk and some charge pipes plus other necessary parts. but someone asnwer me if i can switch to OBD1 on his car? will the OBD2 to OBD1 harness that is sold be able to work on his harness???
are accords harnesses different than those one a civic or integra?
96f22b2
Apr 9, 2009 08:46 AM
