93 honda prelude motor vibration when under load
had a bad motor mount,car drove perfect ,then started getting a vibration. so i pulled the motor and replaced mount along with a few other things . droped motor back in and i am still geting a vibration only when car is undr a load. car rides and steers smooth. it only occurs in a higher rpm range mainly 2gear through 5gear , 1gear slightly . engine runs smooth like new,shifts like new. very confused please help ,any one
but i dont get any poping while turning,im not sure but i thought that a bad cv would make some kind of noise. other than that the shaft looks straight as can be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chase »</TD></TR><TR><TD CLASS="quote">could be a bad shaft or cv</TD></TR></TABLE>
Yup. If it's the inner joint, you won't get any clicking when you turn.
I'm putting a different motor in my non honda fwd car...how to I mount the motor in relation with th
eightvalver
Aug 25, 2006 05:56 AM
