Sway Bar: Will Lightspeed 28mm sway bark snap off the brackets?
Old Dec 31, 2004 | 10:34 AM
DarkBB4's Avatar
Default Sway Bar: Will Lightspeed 28mm sway bark snap off the brackets?
Im debating wheter to keep the sway bar of sell it because im wondienr if the THICK bar will ripp off the brackets like everyone says... What could i upgrade so that woudln't happen? will i feel a huge differnece with the sway bar? is it a difficult instalattoin?
Old Dec 31, 2004 | 12:25 PM
jc836's Avatar
Default Re: Sway Bar: Will Lightspeed 28mm sway bark snap off the brackets? (DarkspeedVtec95)
In keeping with common sense-Neuspeed discontinued their 27mm bar for the 4th gen Prelude because of this specific problem. THey also stopped supplying race teams with the heavy bar for the 5th gen-same reason. Seems that you need more than to just bolt up the heavy brackets-the subframe needs to be reinforced as well.
I would go with a 25mm bar without hesitation if the mounting points are truly solid. You will find that cornering is more precise versus stock, mainly if you use poly bushings.
Old Jan 13, 2005 | 04:58 PM
DarkBB4's Avatar
Default Re: Sway Bar: Will Lightspeed 28mm sway bark snap off the brackets? (jc836)
sorry to bring this back
but basically my sway bar is useless? if u install it.. will it def rip out the brackets?
Old Jan 13, 2005 | 05:00 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bring this back
but basically my sway bar is useless? if u install it.. will it def rip out the brackets?</TD></TR></TABLE>
depends on how you drive really...my buddy had to re-weld his TWICE!
Old Jan 14, 2005 | 02:57 AM
DarkBB4's Avatar
Default Re: Sway Bar: Will Lightspeed 28mm sway bark snap off the brackets? (satan_srv)
another member said Endlinks would solve this?
Old Jan 14, 2005 | 03:56 PM
Hawkze_2.3's Avatar
I just got a Progress 27mm bar and it came with these thick-*** brackets. Hopefully they will hold.....*crosses fingers*
tdhjrh
Apr 5, 2017 05:58 AM
ilvi3tkidxx
Feb 27, 2009 01:24 AM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
