OBX (moroso style) OilPan
Has anyone used one. i just fell across it while searching for a moroso oil pan. searched on here didnt see anything. anyone have any luck. please no OBX SUCKS posts without anything to base your opinion on please. here is the link
http://cgi.ebay.com/ebaymotors...=WDVW
i have one. it will fit on any b-seires motor but type-r. its the same as moroso but alot less. we tried to put it on a type-r but the pick up would not work for some reason. dont know why. i think it was hitting something. same as moroso, like 150 bucks i thing compared to 300.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome »</TD></TR><TR><TD CLASS="quote">i have one. it will fit on any b-seires motor but type-r. its the same as moroso but alot less. we tried to put it on a type-r but the pick up would not work for some reason. dont know why. i think it was hitting something. same as moroso, like 150 bucks i thing compared to 300.</TD></TR></TABLE>
i just bought it. thanks man.
will be doing a write up on it as soon as i install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">looks good, even i dont think obx can **** up an oil pan</TD></TR></TABLE>
you would hope so, but I wouldn't trust them--the oil pan is pretty damn important and you don't want it to fall apart or leak
I really don't think it would be an improvement over the stock one--I mean if you really need something other than the stock one, get the moroso one...even though it is expensive, they are a trusted company that makes nice quality products.
Good luck anyway.
Good luck anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpintyperintegra »</TD></TR><TR><TD CLASS="quote">
Good luck anyway.</TD></TR></TABLE>
using it for the turbo inlet and the added oil quanity.
Who is Mr Robot?
the one thing i was noticing. it says its tapped for a turbo oil return, but look how low both of the bungs are in the pan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">the one thing i was noticing. it says its tapped for a turbo oil return, but look how low both of the bungs are in the pan.</TD></TR></TABLE>
oh WOW! i'd like to contact obx and see if they simply tapped it or if they actually did there homework on where to place it...
good eyes "wantboost"
If u look at the moroso one it has 2 of them in the front. I guess OBX forgot to put the top one. I never understood why moroso has 2 in the front and what is the lower one for?
i installed one on a b20 once and i wound up grinding and welding on it for about 6 hours.first to make it fit,then it leaked out of almost every weld.it cost more to install it than a moroso would have been
I beleive the lweor one is for the oil temp sensor. and there is acutally anotehr bung for oil return. you can't see it in any of the pcitures, but it loosk liek it ahs it's own exit tube into the pan at the bottom right of this pic:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOsT »</TD></TR><TR><TD CLASS="quote">it's pretty hard to mess up a pan, it looks like an o.k. piece...i want to see the write up once you run it on the car</TD></TR></TABLE>
Not really, espically that one. possible things that can be wrong:
-Bad welds (they may either leak, or be weak)
-The flapper on the divider may come loose= no fun for engine
-threads can be tapped wrong, may not seal (on drain and oil inlet holes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">ah, that could be it, so oil doesnt block the line under braking. hmmm. iwondered what that was.</TD></TR></TABLE>
it's so hot oil comin off the turbo gets routed down into the circulating oil, not onto the crank. .
