FS: ACL bearing kit
Kit includes standard main bearings, rod bearings, and thrust washers.
B16, B17, B18A/B, B20 $85
B18C1/5 $88
.25mm oversize is $5 more for each set of rod or main bearings.
Price includes ground shipping to the USA.
Let me know if you need a kit for another car or engine.
Modified by Smoothy at 4:31 PM 1/5/2005
B18C1/5 $88
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoothy »</TD></TR><TR><TD CLASS="quote">Kit includes standard main bearings, rod bearings, and thrust washers.
B18A/B $85
B16, B17, B18C1/5 $88
Let me know if you need a kit for another car or engine.</TD></TR></TABLE>
i think
B18A/B $85
i think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 »</TD></TR><TR><TD CLASS="quote">What size bearing's do you offer</TD></TR></TABLE>
ACL's are usually comparable to Green Honda bearings which is right in the middle of the color chart which usually are within spec. I run ACL's now in my daily driver and have never had a problem.
btw...any more sets available for the b1's? BUMP for Smoothy
I have both standard and .010 oversized which is a few dollars more, depending on which bearings you want oversized.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKchump »</TD></TR><TR><TD CLASS="quote">
btw...any more sets available for the b1's? BUMP for Smoothy</TD></TR></TABLE>
Yes, I have quite a few.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daygo_beanR »</TD></TR><TR><TD CLASS="quote">any way that you can sell main bearings for b16 and rod bearings for b18 separate??? how much?? thanks</TD></TR></TABLE>
If you want b16 kit with B18B rod bearingss, then its $85. $88 if you want the B18C rod bearings.
Bump cause im going to try to get me a set for my ls/vtec!
question.......for b18a1 bottom end have u heard of people using the acl's for like a gsr or itr on the b18a1 oem parts?
im still going to use my LS rods w/arp 8-mm rod bolts and .25 oversized pr-3's?
just wondering cause i have seen a couple of people say they use gsr or itr acl bearings for LS.
i just dont want to get me a set that wont work.
if its a hassle ill just stick with the LS acl's
thanx
also do u have a complete set for GSR's in stock?
might have a buddy interested and also how long would that take to get shipped to Bay Area CA 94545
what type of payments do u except?
thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMboy »</TD></TR><TR><TD CLASS="quote">Bump cause im going to try to get me a set for my ls/vtec!
thanx
what type of payments do u except?</TD></TR></TABLE>
I'm unaware of any benifits from using the ITR rod bearings. Unlike OEM honda, the ACL bearings are manufactured the same (but they are not the same bearing). And I believe you have to do some machine work to get them to fit/work properly.
I do have a kit for the GSR/ITR in stock. I take Paypal and my address is the one listed in my profile. Shipping to CA generally takes a week.
thanx
