Energy Suspension mount inserts, question???
Old Dec 30, 2004 | 05:45 PM
NJP17's Avatar
Default Energy Suspension mount inserts, question???
i have a dohc 95 del sol i bought the ones for the sohc del sol they said it should fit. it doesnt fit. does anyone know what kit works on the b16 delsol?
Old Dec 30, 2004 | 05:46 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Energy Suspension mount inserts, question??? (NJP17)
just order the kit for the 99-00 si and you should be fine.
Old Dec 30, 2004 | 05:49 PM
2lua's Avatar
be ready for interior vibrations.
Old Dec 30, 2004 | 05:55 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">be ready for interior vibrations.</TD></TR></TABLE>
I have the inserts and can honestly say that I don't notice any additional vibration. I believe this is because it's only the transmission torque mounts that are done and not all the upper engine mounts. For the people that I know that did swaps and installed aftermarket poly engine mounts, they tend to be the ones that experienced the extra vibration.
Old Dec 30, 2004 | 05:57 PM
DJ_SaNdOz's Avatar
Default Re: (00Red_SiR)
I installed the es inserts in the motor & tranny mounts all around in my EG & I do notice more vibration at idle, but it's not as bad as people say that it is.
Old Dec 30, 2004 | 06:02 PM
2lua's Avatar
oh yeah! if you only change 1 out of 5 then there next to no vibration, but if i change en insert then i would change the torque mounts.
Old Dec 30, 2004 | 06:06 PM
DJ_SaNdOz's Avatar
Default Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah! if you only change 1 out of 5 then there next to no vibration, but if i change en insert then i would change the torque mounts. </TD></TR></TABLE>
I added the inserts to all of them
EDIT: but I have a SOHC if that makes a difference....
Old Dec 30, 2004 | 06:11 PM
2lua's Avatar
Default Re: (DJ_SaNdOz)
i did prelude h22 2 mounts front and back, 92 hb gsr rear, 2 torque mounts, crx 2 mounts front and back, those car buzz like crazy... especially the crx i got 1 hella headache after 30 min test drive.
Old Dec 30, 2004 | 06:36 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: but I have a SOHC if that makes a difference....</TD></TR></TABLE>
The Energy Suspension mount inserts I got only came for the 3 lower torque mounts. I never saw any available for the other engine mounts, but you say you got some for yours? what brand were they?
Old Dec 30, 2004 | 06:48 PM
DJ_SaNdOz's Avatar
You're right on the ES for the 3 lower. My GF's dad installed them when I was on vacation earlier this year. I'll ask him and get back to you.
Old Dec 31, 2004 | 05:30 AM
NJP17's Avatar
i think the 99 mounts are way different
Old Dec 31, 2004 | 10:10 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (NJP17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJP17 &raquo;</TD></TR><TR><TD CLASS="quote">i think the 99 mounts are way different</TD></TR></TABLE>
How could they be different if they are both Civics using the same engine and transmission configuration?
Old Dec 31, 2004 | 11:25 AM
vtec69's Avatar
i have all of them except for the driverside mount cause its a gs-r mount and everything in the car vibrates
LOL
just have to tighten a lot of stuff like once a month
Old Dec 31, 2004 | 05:09 PM
NJP17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
How could they be different if they are both Civics using the same engine and transmission configuration?</TD></TR></TABLE>[QUOTE=00Red_SiR]
because the ek mounts are way different from the eg mounts
Old Dec 31, 2004 | 05:50 PM
Ricey McRicerton's Avatar
Default Re: (NJP17)
I have 2 of the 3 (haven't put the rear mount in yet) on my EK hatch and I do notice more interior vibrations. I don't know if I even want to put in the last one.
Old Dec 31, 2004 | 06:12 PM
sleeping GIANT's Avatar
Default Re: (Ricey McRicerton)
I have the two fronts and the rear engine mount inserts and Im not going to lie it vibrates alot. but after a year and a half of driving it Ive got used to it. plus I feel as if it helps quite a bit on wheel hop. dont put these in if you dont like **** vibrating! DONE
Old Dec 31, 2004 | 08:27 PM
upgraded's Avatar
I havd a 92 civic with b16 and I have the 95 Del sol doch kit in mine. can't rember if its prothane or ES though, but there is a kit for the dohc del sol, just so you know.
Old Jan 1, 2005 | 11:38 AM
NJP17's Avatar
Default Re: (upgraded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by upgraded &raquo;</TD></TR><TR><TD CLASS="quote">I havd a 92 civic with b16 and I have the 95 Del sol doch kit in mine. can't rember if its prothane or ES though, but there is a kit for the dohc del sol, just so you know.</TD></TR></TABLE>
es doesnt have a kit specifically for the dohc i called them and they said theyre not sure if it would work. im trying to search to see if prothane has one.
and for all the comments about vibration. i know it vibrates ive had them on many cars before. that was not my question.
thanks
Old Jan 1, 2005 | 11:47 AM
ABK's Avatar
ABK
Default Re: (NJP17)
I put in full suspension bushing kit into a hatch, it was one of those black bushing series not the harder red stuff. Didn't notice no vibration, the only new bushings I didn't have on that car were engine mounts (which obviously cause vibration), car just felt hell out of nicer and solid.
MadCoder
Nov 29, 2012 01:09 PM
truejdm2
Mar 12, 2008 08:30 AM
ls_bitik
Aug 1, 2007 12:14 PM
GetawayInMoscow
29
Mar 2, 2006 09:23 AM
o'malley_808
Sep 30, 2005 10:33 AM
