Sleeved / Built GSR Block 4 Sale!!! Brand New!!!!
Brand new build. Details below. Pics up soon!
B18C block w/ GSR crank, 84.5mm bore, decked and o-ringed
Golden Eagle Mfg. HD sleeves
Eagle big bolt rods
Wiseco Pistons 84.5 mm 8.8:1 comp. ratio
King main bearings
ACL rod and thrust bearings
Line bored
Bored and honed
Balanced rotating assembly
Sized, micro-polished and magnafluxed crank
Chamfered oil hole
Factory oil pump
GSR baffle pan, oil pickup and oil pan included. Pan not installed so you can modify it for your oil return location!
All brand new seals throughout
Bead blasted to look brand new.
Ready for head installation and comes with factory OEM 84.5 mm head gasket!!!
$3420.00 no core required!!!
Built by Golden Eagle Mfg. / Vince Tiaga. Everything is brand new on this block!!!
Sleeved on 12/2/04
Finished built on 12/20/04
Serious inquiries ONLY!
Thanks and Happy New Years!
Vince Tiaga
Eagle big bolt rods
King main bearings
Line bored
Bored and honed
Chamfered oil hole
Factory oil pump
Sleeved on 12/2/04
Vince Tiaga
2literCR-X
Feb 1, 2009 12:38 PM
X-Mazda 3 Racer
Mar 25, 2005 01:31 PM
