99 gsr header -> cat -> exhaust fit on other integs??
as the topic says..
my cat has 2 o2 bungs, does the whole header back exhaust on my 99 gsr fit any other integras besides 94-99 gsr? (ie, 94-99 LS? or 00-01 gsr?)
edit: shystrdygsrtdy posting on this name
well i haven't tried this but it should work fine. I THINK def. if you don't mix and match parts. also you won't be needing the second bung. i put a 99 gsr header on my ls and that was the same specs besides diameter.
the '99 Gs-R header + cat + exhaust when used togther will fit any Integra.
FYI the '99 Gs-R header + cat = standard length of a JDM header + JDM cat, and as such, the exhaust is also JDM length.
