JDM cluster wiring?
All the important wiring is now working! Below is a schematic that I have found to work.
There are 2 plugs on the top (one 10 pin with a full harness and one 6 pin with no harness), and 1 plug on the side (16 pin connector which is used only with a automatic transmission).
The top 10 pin connector has the coding:
1- tachometer
2- ?
3- ?
4- ?
5- speedometer
6- ground
7- ?
8- ?
9- 4ws
10- power
The top 6-pin
1- blinker
2- high beam
3- high beam
4- blinker
5- ?
6- ground
I have also not yet determined where the lights and dimmers connect...but there are not that big of a deal.
Enjoy!
Modified by XES at 7:05 PM 1/4/2005
1- tachometer
2- ?
3- ?
4- ?
5- speedometer
6- ground
7- ?
8- ?
9- 4ws
10- power
The top 6-pin
1- blinker
2- high beam
3- high beam
4- blinker
5- ?
6- ground
Enjoy!
84-POV
Jul 14, 2006 07:23 PM
