Question about door wiring
I was wondering if it was possible to add a courtesy light to the doors, if there is existing wiring I can tap into or something?. I'm new at this, so I'm not sure if this can be done easily. Maybe a sensor in the door that I can tap into? The car is a '97 gs-r. Thanks in advance.
The trigger that triggers the dome light is actually a negative trigger. I think there is already a 12V source in the door (for switches, windows, etc) and i know that the negative door trigger can be found in the driver kick panel. you can find the color code on the12volt.com . I wired some CCFL under the dash of the passenger and driver so that it would light up the floor when the door opens using that trigger wire.
Thanks for the info guys, but I just wanted to get one thing clear for me. Are both pass. and driver side door triggers in the driver side kick panel? Or if there's only one triger then both courtesy lights will light if one door is open right? TIA
alscrx
Honda Civic (2001 - 2005)
Jan 5, 2009 06:53 PM
skydiveterp
Mar 19, 2007 06:09 AM
