Cams and pistons in SIR-G
Old Dec 30, 2004 | 07:06 AM
BLK99VTECR's Avatar
Default Cams and pistons in SIR-G
On my SIR-G my current set up is:
AEM CAI
High flow cat
Apexi N1 exhaust
DC JDM 4-1 header
Fidanza 7lb flywheel
Exedy Organic clutch
VAFC2
FPR
Before the flywheel and clutch the car was running 14.6-14.7 at best . My goal for this season is to hopefully get a 13.7-13.9 out of the car. Since I already have just about all the bolt ons except Skunk IM, im trying to decide what internal set up to go with. The car is a daily driver so i need to keep it as reliable as possible while at the same time making as much power as possible to reach my goal.
My options for cams are CTRs or Skunk1s
Pistons can CTRs but based on what I have read JDM ITRs may be a better choice for me.
Out of my options listed, what seems to be the better choice to get me where I wanna be ?
Old Dec 31, 2004 | 05:37 PM
BLK99VTECR's Avatar
Default Re: Cams and pistons in SIR-G (BLK99VTECR)
Old Jan 1, 2005 | 01:12 AM
michael O's Avatar
Sorry for my ignorance what's a sir-g again? b16 or b18?
Old Jan 1, 2005 | 01:57 AM
eda6's Avatar
Default Re: Cams and pistons in SIR-G (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for my ignorance what's a sir-g again? b16 or b18?</TD></TR></TABLE>
jdm gsr
Old Jan 1, 2005 | 08:41 PM
BLK99VTECR's Avatar
yea, difference of 10.6 compression to USDM 10.1. Very good swap to do if u can get away with it with your local law
Old Jan 2, 2005 | 03:53 AM
JDM Like Whoa's Avatar
I would say go with the ITR's but that is just me. CTR's will sit you a little high compression wise. Also, if depends on what you are looking at doing... so far, it seems like you are doing an all motor build so I would look into TODA. http://www.todaracing.com They are the **** when it comes to all motor.
All in all.. I (being a SiR-G Owner) would just spray and call it a day. With a 55 wet of NX, you will be doing 13's easily. Daily driving wont be a hassle since you can turn the bottle on and off or even take it out.
Modified by ImportRacr05 at 9:08 AM 1/2/2005
Old Jan 2, 2005 | 04:45 AM
mrDFWmechanic's Avatar
go with the itr's
Old Jan 2, 2005 | 06:44 AM
BLK99VTECR's Avatar
Default Re: (ImportRacr05)
yea you got a point there, 55 show and CTR cams right
Old Jan 2, 2005 | 09:04 PM
With a 55, I would keep your GSR or SiR-G cams... These cams are the best for any kinda F/I Applications... Thats unless, you go with a nitrous cam.
Old Jan 4, 2005 | 01:03 AM
BLK99VTECR's Avatar
i think ii still want a 13 second all motor car first
Old Jan 4, 2005 | 10:52 AM
Default Re: (BLK99VTECR)
In that case... ITR Cams, Springs, Retainers, Drag radials, ITR Manifold, skunk2 manifold, and a VAFC will get you there.
Old Jan 4, 2005 | 02:53 PM
BLK99VTECR's Avatar
yea and a 2.5 inch exhaust
Old Jan 4, 2005 | 03:56 PM
BLK99VTECR's Avatar
accoroing to the C-Speed calculater which may or may not be correct, my options are:
CTR Pistons and OEM Head gasket @ 12.0 compression
JDM ITR Pistons + Mugen head gasket @ 11.6 compression
Or I can spend a couple hundred bucks and get fordge JE high compression pistons which may be a waste of money cause I dont plan to increase my redline.
So basically between those choices, I want which ever one i can drop in my motor on my GSR rods with no modifications required, and will run efficiently with for daily driving and still make good power.
I have also decided that since im not changing the red line that im just gonna go ahead and run with CTR cams
Old Jan 6, 2005 | 04:10 AM
For daily driving, I prolly would suggest the ITR pistons.
FYI... this is gonna cost you some money dude... machine shops arent cheap... thats unless your doing it yourself.
Old Jan 10, 2005 | 07:39 PM
BLK99VTECR's Avatar
so whats gonna be the expenses besides parts
Old Jan 10, 2005 | 09:43 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK99VTECR &raquo;</TD></TR><TR><TD CLASS="quote">so whats gonna be the expenses besides parts</TD></TR></TABLE>
tuning
Old Jan 11, 2005 | 11:53 AM
BLK99VTECR's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">tuning </TD></TR></TABLE>
thats not a problem when you have good relationshis with resourceful peole
confusatron
Mar 25, 2006 12:23 AM
broketuner-Sol_Si
Dec 1, 2005 09:33 AM
vgsr
Feb 14, 2005 05:30 PM
CivicTypeR00
May 23, 2004 10:01 PM
JunIntegra
10
Jan 4, 2004 11:33 AM
