D series flywheel bolts
Old Dec 30, 2004 | 06:51 AM
Boosthead's Avatar
Default D series flywheel bolts
I read that the B series flywheel bolts are 17mm 12pt. Does anyone know if D series are the same? Just want to make sure I'm prepared when I pull my tranny on Saturday.
Old Dec 30, 2004 | 07:44 AM
B20badboy's Avatar
Default Re: D series flywheel bolts (Boosthead)
Its been awhile but they are 12piont a little smaller i think.
Old Dec 30, 2004 | 09:30 AM
BignevadaBoB's Avatar
they are the same. I had to use the ones off my d16 when I did a b18 swap.
Old Dec 30, 2004 | 01:06 PM
PABLOHONDA's Avatar
Default Re: D series flywheel bolts (BignevadaBoB)
NO THEY ARE NOT THE SAME I JUST DID MY GSR SWAP AND I HAD TO GET BOLTS FROM SOME FRIENDS
Old Dec 30, 2004 | 01:32 PM
Boosthead's Avatar
Default Re: D series flywheel bolts (PABLOHONDA)
not the same length or not the same head size?? I have bolts, just want to make sure I have the right sockets.
Old Dec 30, 2004 | 01:53 PM
PABLOHONDA's Avatar
17 or 19 12pt i cant remember but aslong as you got 17-18-19 pt you should be fine
Old Dec 30, 2004 | 04:18 PM
Burke's Avatar
Banned
did this YESTERDAY. and MANY times in the past. d-series flywheel bolt heads are 12pt 17mm. same with b-series. although i dont know is the pitch on the threads is the same.
i pulled fly wheel bolts off a d16y7 auto and the bolts had AT stamped on them. pulled bolts off a d15b7 yesterday and they did not. i dont know whatn that is supposed to mean, but i thought i would throw it in
edit - clutch bolts are 12pt 10mm and torque convertor bolts are 6pt 10mm
Old Dec 30, 2004 | 04:35 PM
Boosthead's Avatar
Default Re: D series flywheel bolts (Burke)
Great info. I have alot of work ahead of me this weekend including replacing the clutch, flywheel, axles, shifter, ushings, turbo kit and I don't want anything slowing me down
Old Dec 30, 2004 | 04:40 PM
2fast4u831's Avatar
I'm really 2slow
Automatic flywheel bolts are smaller than manual ones so STAY AWAY from those, and yes the have AT stamped on them. I wouldnt recommend using AT flywheel bolts.
cranker
Jun 16, 2010 05:39 AM
dadrought6
Feb 22, 2009 11:00 AM
nitroice40
Apr 15, 2007 07:28 AM
team1320_k26eg
Jan 13, 2007 05:35 PM
