Factory 2.3 H-series VTEC ?
sorry about my ignorance, all my knoweldge is about B series engines
but is there a H23 that has VTEC from the factory? I was under the impression that there wasn't, but recently someone said there was.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Preludeguy »</TD></TR><TR><TD CLASS="quote">Im guessing its pretty rare since almost no one knows about it.
Yeah well it is described in the FAQ...which if everyone read, everyone would know about.
</TD></TR></TABLE>Yeah well it is described in the FAQ...which if everyone read, everyone would know about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">they are station wagon engiens good for a novelty, but nothing spectacular. plus the few people i have known who had them spun bearings a little more often.</TD></TR></TABLE>
uhh..so who are all these people that spun bearings with OEM JDM H23A VTEC motors??
And the mains on the H23A VTEC crank are larger, 55mm like the newer preludes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikester_91 »</TD></TR><TR><TD CLASS="quote">I had a friend w/ a 2002 honda accord special edition, and when i popped the hood, the sticker said 2.3L, and the valve cover said VTEC, so there u go.</TD></TR></TABLE>
F23A1 SOHC VTEC
F-series, single cam.
F23A1 SOHC VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">
F23A1 SOHC VTEC
F-series, single cam.</TD></TR></TABLE>
Yep that wansn't an H23 man.
F23A1 SOHC VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">uhh..so who are all these people that spun bearings with OEM JDM H23A VTEC motors??
And the mains on the H23A VTEC crank are larger, 55mm like the newer preludes...</TD></TR></TABLE>
well you want their names and numbers or are you just being an asshat?
they revved the **** out of the negines and spun rod bearings....what do the mains have to do with that? the H23 bottom end doesnt want to rev as high to make the same power, i thoguht that was obvious form the issues that people see with h23 engines....
idiot, anyways this motor was actually awd i think, but not sure, also it has a little more power. Unreliability goes hand in hand with who owns the motor. If you take care of it, it will do you find.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22edAccord »</TD></TR><TR><TD CLASS="quote">idiot, anyways this motor was actually awd i think, but not sure, also it has a little more power. Unreliability goes hand in hand with who owns the motor. If you take care of it, it will do you find.</TD></TR></TABLE>
wrong
it has 197 hp aka 200ps
it has a little more torque (3-4 lb/ft) than the h22a though and both the power AND torque come in lower. all of which were better for a heavier car with auto (all teh time last tim e i check http://www.honda.co.jp) AND AWD (most of the time)
you take an h23 that revs to 6800 rpm and rev it to 7600rpm then it WILL wear bearings faster. you need "proof"? read this forum in regards to h23's spinnging bearings.
wrong
oh really? So explain this to me, I had a jdm h23A in my other daily driver, stock everything down to a stock p13. I by far beat the **** out of it, but did shift her at stock redline often. And ended up with a few spun rod bearings. Yet on my modded h22a with a stock bottom end, i beat the **** out of it, and shift at 8,200rpm, but the block is still perfectly fine? i suppose its the owner huh?
they revved the **** out of the negines and spun rod bearings....what do the mains have to do with that? the H23 bottom end doesnt want to rev as high to make the same power, i thoguht that was obvious form the issues that people see with h23 engines....</TD></TR></TABLE>
cuz we all know you have to beef up the main journals to prevent spining rod bearings, its the H-T way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">wrong
you take an h23 that revs to 6800 rpm and rev it to 7600rpm then it WILL wear bearings faster. you need "proof"? read this forum in regards to h23's spinnging bearings.</TD></TR></TABLE>
There talking about the h32 vtec from factory. Not the h23 non vtec block with a h22 head. I think your confused. Im pretty sure the h23 vtec block is diffrent then the h23 nonvtec block. Im sure it can handle high revs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix »</TD></TR><TR><TD CLASS="quote">There talking about the h32 vtec from factory. Not the h23 non vtec block with a h22 head. I think your confused.</TD></TR></TABLE>
no i didnt misunderstand
the factory h23 vtec uses the longer stroke and shorter rods.....just like the non vtec h23.
i got my information directly fromt eh http://www.honda.co.jp website. thoguh its hard as hell to find that stuff now since they removed it middle of last year.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix »</TD></TR><TR><TD CLASS="quote">Oh ok i wasnt trying to be a dick or anything. I didnt know that info
.</TD></TR></TABLE>
no problem, i jsut dont like some peoples attitudes, you are nto one of them though. i wish i had saved the spec sheets when they were publicly and easily available.
.</TD></TR></TABLE>no problem, i jsut dont like some peoples attitudes, you are nto one of them though. i wish i had saved the spec sheets when they were publicly and easily available.
jdm_ludester
Sep 26, 2003 08:19 AM
