TRANSMISSION- Clutch/Flywheel Torque Specs for 99 b16a2
Old Dec 29, 2004 | 08:33 PM
teamm_AP1's Avatar
Default TRANSMISSION- Clutch/Flywheel Torque Specs for 99 b16a2
Hey, Anyone know the Clutch and Flywheel Torque Specs for the 1999 B16A2?
Also, the Torque specs for the motor mounts (Drvier side, Tranny Mount, AC Bracket, and rear mount)
Thanks in Advance!!
Old Dec 30, 2004 | 01:26 AM
teamm_AP1's Avatar
Default Re: TRANSMISSION- Clutch/Flywheel Torque Specs for 99 b16a2 (MiSCHiEF_EK)
bump!
Old Dec 30, 2004 | 09:01 AM
torr's Avatar
flywheel- 87 ft/lbs
clutch- 19 ft/lbs
driver side- 40 ft/lbs
tranny top mount - no torque specs, except for the bolts that connect the round mount to the chassis,is - 47 ft/lbs
ac bracket- from ac bracket to the block is 33 ft/lbs. from the ac bracket to the chassis is also 33 ft/lbs
rear mount - from the moun to the block is 43 ft/lbs and then the moun to the chasis is also 43 ft/lbs
Old Dec 30, 2004 | 07:10 PM
teamm_AP1's Avatar
Default Re: TRANSMISSION- Clutch/Flywheel Torque Specs for 99 b16a2 (torr)
Thank you... THat was very informative!
raiden571
Feb 14, 2008 05:20 AM
transpar_nt
Nov 24, 2005 02:40 AM
nubs
Dec 14, 2004 10:22 AM
NZDelsoldude
Dec 5, 2004 02:56 PM
