mesh grille tutorial
Old Dec 29, 2004 | 07:55 PM
D for D series's Avatar
Default mesh grille tutorial
Alright, this is how to get a mesh grille with out spending alot of money,
1.Go to any hardware store and buy mesh gutter guard
2.Take off your front bumper and grille
1a.There is one bolt in each wheel well, remove them
2a.2 on the underside of the bumper (maybe others)
3a.Pop up the hood and there are 6 plastic bolts that need to be removed
4a.pull the bumper toward you
5a.U need a little screw driver and undo all the screws on the grille
3. take a saw and cut out around the inside of the grille
4.cut the mesh with wire snips to the right size
5.after cut there are 4 latches try to hook the latches un but if you cant its ok because you can screw the mesh in
6.put all of hte bolts back in to the right holds and put the bumper back on
7.you are done
IF YOU PAINT IT BESURE TO ADD A CLEAR COAT BECAUSE THE PAINT WILL COME OFF WHEN U WAS YOUR CAR AT THE CAR WASH
Old Dec 29, 2004 | 07:58 PM
civictildeath's Avatar
Default Re: mesh grille tutorial (ZeroSkate9119)
damn i knew i shouldnt have spent $5 for 6 feet off the net thanks for the short cut though. i did a 97 talon they suck. got to take the headlamp out to get the bumper off but you got to take the bumper off to get the headlamp out what a pain
Old Dec 30, 2004 | 12:16 AM
parasonic's Avatar
I just bought a 99/00 si grille. Looks way better.
Old Dec 30, 2004 | 01:11 AM
JDM Like Whoa's Avatar
Default Re: mesh grille tutorial (parasonic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parasonic &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 99/00 si grille. Looks way better.</TD></TR></TABLE>
X120012403043200342 katrillion!
Old Jan 10, 2005 | 06:50 AM
Hazem's Avatar
Default Re: mesh grille tutorial (ImportRacr05)
damn lucas everybody knows this, it's a DIY ctr style grill...search and you'll get 125150810581085150815 topics on how to do it
Good job though, even though yours is ghetto.
haha
aeboync
Jan 7, 2006 05:24 PM
D for D series
Jan 8, 2005 10:46 PM
AcuraTLinspired
Acura TL, RL & ZDX
Dec 8, 2003 01:01 PM
AGB5901
15
Nov 24, 2003 06:31 PM
Quik89Si
Apr 17, 2002 11:01 AM
