ZC Motor?
Sup everyone. As you can see by my login name I'm obviously new at dis. Anyone in here know what years the ZC motor was made? I just got an '88 CRX and it's got a 1.6 ZC motor and I'm just trying to figure out what year it is. It's a pretty quick car but I'm trying to see what or where to look to determine why the idle is fluctuating when the car is warmed up. It fluctuates between 300-1000rpm. Occasionally it would almost completely die. My friend told me that it could be a vacuum leak. But I don't know where to start.
Anything you can provide I'm more than happy to listen. Thanx!
i don't see it. you have any idea what years that engine was made? how about the fluctuation in the idle. any idea what that maybe caused from? does anyone know of a good way to test for vacuum leaks? I was told to use windex, something that causes bubbles. but if it's a vacuum leak wouldn't it just suck inwards? I need help! All I wanna do is get this thing on the road with no problems. It's damn embarassing to have all that power and die at the light if you know what i mean.
All suggestions are welcome!
Well the ZC had been made in Japan for years 85ish to at least the mid/late 90's. you most likely have a 88-91 engine. The only way to tell the year was explaned above. As far as the Idle do a search it common place I know when it happend on my Friends ZC it was his fast idle Valve after he replaced it the zc was fine.. Also welcome to Honda-Tech
South Bay Surfer
Aug 20, 2004 05:36 PM
