TIMING BELT HELP!!
Old Dec 29, 2004 | 06:51 PM
ElectronSi's Avatar
Default TIMING BELT HELP!!
Ok, my problem is in my b16a2 my timing belt skipped a tooth. Theres a spring to tighten the timing belt and what not, I had to reatach the spring and when i was putting it into place the spring stretched, it made a KLANG kinda noise. What can i do to fix this!?
Old Dec 29, 2004 | 06:53 PM
civictildeath's Avatar
Default Re: TIMING BELT HELP!! (ElectronSi)
buy a new one
Old Dec 29, 2004 | 07:03 PM
_BEN_'s Avatar
That sucks. I have had that happen to me before.
First thing would be to fish out all of the pieces of the spring and the sleeve that goes over it. If you don't the pieces could damage your belt.
The spring is not 100% necessary to have on there. It is more of a convenience so atleast you wont be stranded without a car. Just push the tensioner over with a long screwdriver to get the correct tension.
Old Dec 29, 2004 | 07:05 PM
Default Re: TIMING BELT HELP!! (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote"> Just push the tensioner over with a long screwdriver to get the correct tension. </TD></TR></TABLE>
now how do you keep the tension on it then??
Old Dec 29, 2004 | 07:06 PM
_BEN_'s Avatar
Default Re: TIMING BELT HELP!! (civictildeath)
The spring helps you set the tension then you tighten the bolt.
Its hard to tell in this pic but the hole that goes through the center of the tensioner is oval shaped. You adjust the tension, then you tighten the bolt and its set.
Hehe that spring would have to be a hell of a lot stronger to hold the tension if thats what it was there for.
Modified by _BEN_ at 8:25 PM 12/29/2004
Ge-money
Mar 24, 2010 06:35 AM
Lambo123
Sep 7, 2009 10:25 AM
zeplin
Jan 25, 2009 07:44 AM
timlush
Jan 9, 2007 04:22 PM
92B20GSR
Nov 17, 2003 02:04 AM
