Does my car use "high" or "low" impedance injectors??
I have a 92 civic Si with a full OBD1 GSR swap. I am planning on ordering injectors very soon so can you help me by telling me if I should run low or high impedance injectors...? THX
You want high impedence(aka. saturated injectors) for your car. You can run low impedence(aka. peak & hold injectors), but you'll have to wire in a resistor box. For simplicity's sake, just run the saturated injectors.
RC makes saturated injectors from 155cc up to 750cc. Anything larger than 750cc you'll have to run peak and hold injectors.
Khoi
Khoi
is there a difference between the usage of peak and hold and saturated if i am going to run boost on my engine??
thanks for the help!!
bigblue7t6
Engine Management and Tuning
Oct 5, 2012 08:31 PM
