300 rpm idling
Old Dec 29, 2004 | 04:51 PM
CRX_Control's Avatar
Default 3000rpm idling
so i have this idle that iv been trying to fix for a while , when i unplug my map sensor it goes down a bit , then when i unplug my tps sensor , it goes down to 1500 rpm, i really want to know whats causing this and can a bad iacv cause a 3 k idle? i ment 3000 rpm idle
Old Dec 29, 2004 | 06:21 PM
ridexstraight's Avatar
Default Re: 3000rpm idling (CRX_Control)
have u tried the idle adjust screw, that helped me a lil bit
Old Dec 29, 2004 | 06:26 PM
ef8 h0!'s Avatar
Default Re: 3000rpm idling (ridexstraight)
check for leaks on the tb and im.
Old Dec 29, 2004 | 06:38 PM
PHOBIA's Avatar
i gurantee you its the iavc valve.block it off and tighten it back down if it goes away then thats it.trust me ive been through more of these parts than tires.
Old Dec 29, 2004 | 07:04 PM
eda6's Avatar
Is your tb stuck open? Throttle cable sticking? If that checks out, time to leak check with carb cleaner.
Old Dec 30, 2004 | 11:03 AM
Default Re: 3000rpm idling (eda6)
well i figured it out , you know the other other idle screw that is located on the tb and can only be adjesuted with a alen wrench? well i adjesuted that and now its perfect .
eskerley
13
Apr 16, 2008 02:59 PM
takeit
Sep 11, 2007 06:31 PM
go2sleep
Jun 15, 2006 08:54 PM
MIKES
Jul 17, 2002 12:19 PM
