what is the most i can rev my usdm type r motor.
Old Dec 29, 2004 | 04:34 PM
aser1z's Avatar
Default what is the most i can rev my usdm type r motor.
What is the regular redline on a usdm type r andf what can i rev with my milled head and crower valve springs and retainers?
Old Dec 29, 2004 | 04:35 PM
thk's Avatar
thk
Members Only
Default Re: what is the most i can rev my usdm type r motor. (aser1z)
Depends on your ECU?
Old Dec 29, 2004 | 04:51 PM
Nishant's Avatar
Default Re: what is the most i can rev my usdm type r motor. (thk)
without ecu change, no point in reving past 8400rpm
Old Dec 29, 2004 | 04:55 PM
Chris F's Avatar
Default Re: what is the most i can rev my usdm type r motor. (Nishant)
I bet you could get it to 12,000 RPM if you downshift from 5th to 2nd at 100 MPH.
-Chris
Old Dec 29, 2004 | 05:45 PM
btotherizzle's Avatar
Default Re: what is the most i can rev my usdm type r motor. (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I bet you could get it to 12,000 RPM if you downshift from 5th to 2nd at 100 MPH.
-Chris
wawawawaaaaaaaa. I do this all the time. Because I'm one of life's winners.
Old Dec 29, 2004 | 05:50 PM
danny98r's Avatar
they made the fuel cutoff at 8650 for a reason dont go past that
Old Dec 29, 2004 | 10:28 PM
ITR 2K's Avatar
15,000.
Old Dec 29, 2004 | 10:34 PM
BS 22's Avatar
Default Re: what is the most i can rev my usdm type r motor. (ITR 2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 2K &raquo;</TD></TR><TR><TD CLASS="quote">15,000.</TD></TR></TABLE>
easily.
Old Dec 29, 2004 | 11:18 PM
KayOs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aser1z &raquo;</TD></TR><TR><TD CLASS="quote">What is the regular redline on a usdm type r andf what can i rev with my milled head and crower valve springs and retainers?</TD></TR></TABLE>
Feeling a little curious and destructive today?
Old Dec 29, 2004 | 11:47 PM
Kendall's Avatar
Default Re: what is the most i can rev my usdm type r motor. (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">Feeling a little curious and destructive today? </TD></TR></TABLE>
Or perhaps a LOT curious and destructive today.
Old Dec 30, 2004 | 08:15 PM
Azcheron's Avatar
Default Re: what is the most i can rev my usdm type r motor. (Kendall)
id say somewhere between 8 and 9......
million..that is!
ive heard that a Hype R can hit over 200 mph in reverse too!
ya! all you have to do is drive backwards off a mountain...
Old Dec 30, 2004 | 08:29 PM
integra_type-r's Avatar
Default Re: what is the most i can rev my usdm type r motor. (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">id say somewhere between 8 and 9......
million..that is!
ya! all you have to do is drive backwards off a mountain...</TD></TR></TABLE>
HAHAHAHHAAHHA!!!!!
Old Dec 30, 2004 | 09:17 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">without ecu change, no point in reving past 8400rpm</TD></TR></TABLE>
errrnt
Old Dec 31, 2004 | 10:29 AM
million..that is!
I'm sorry but gravity wouldn't allow it much past 125mph.
Old Dec 31, 2004 | 11:03 AM
92TypeR's Avatar
FSAE
Default Re: what is the most i can rev my usdm type r motor. (btotherizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sorry but gravity wouldn't allow it much past 125mph.</TD></TR></TABLE>
Ehh...Im pretty sure that the only thing gravity is doing is keeping the car stuck to the ground. Wind resistance and POWER is what keep the ITR limited. 200hp can only go so far.
As for the topic at hand, you will want to shift as soon as your powerband starts to fall. For a stock USDM ITR, this usually occurs around 8100-8300rpms, of course that doesn't mean it CAN'T go higher, which is why the motor has fuel cut at ~8500rpms. If you have aftermarket cams that can potentially raise where peak power occurs, a dyno is the only real way to determine when to shift.
Dont forget that your valvetrain plays a key role in how high in the RPM's you should go. Valve float can happen after 8900 or so with stock or similar cams and stock valvetrain. Some aftermarket springs/retainers allow trips to 10k or more, but odds are you aren't making power up there, so there is no point, all you do is risk seroius damage to the motor.
Just because you CAN revv high, doesn't mean you SHOULD.
Old Dec 31, 2004 | 12:14 PM
SMZ GSR's Avatar
Default Re: what is the most i can rev my usdm type r motor. (92TypeR)
LMAO @ this thread
Old Dec 31, 2004 | 12:15 PM
chad's Avatar
Moderator
13,900 is the highest i've taken mine
Old Dec 31, 2004 | 12:31 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
Ehh...Im pretty sure that the only thing gravity is doing is keeping the car stuck to the ground. Wind resistance and POWER is what keep the ITR limited. 200hp can only go so far. </TD></TR></TABLE>
Actually, I believe he was referring to terminal velocity, in which case gravity is basically the only thing "propelling" the vehicle, and horsepower has nothing to do with the equation.
Old Dec 31, 2004 | 12:40 PM
Opie's Avatar
I have in car video from Expo 4 of my R pinning the tach going into T1 @ Beaver Run with Chris N sitting shotgun going, "Oh ****, oh ****, oh boy, o ****"
Old Dec 31, 2004 | 01:23 PM
slowhtwgn's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">I have in car video from Expo 4 of my R pinning the tach going into T1 @ Beaver Run with Chris N sitting shotgun going, "Oh ****, oh ****, oh boy, o ****"</TD></TR></TABLE>
That i'd like to see.
Old Dec 31, 2004 | 01:40 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (slowhtwgn)
10k
Old Dec 31, 2004 | 01:42 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (Stunna BEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna BEN &raquo;</TD></TR><TR><TD CLASS="quote">10k</TD></TR></TABLE>
only in fif geer
Old Dec 31, 2004 | 01:48 PM
Stunna BEN's Avatar
Default Re: (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">
only in fif geer </TD></TR></TABLE>
I beg to differ!
MYself and Len did this in 2nd gear, usdm style!
Actually, i believe we passed 10k
Old Dec 31, 2004 | 03:05 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
wawawawaaaaaaaa. I do this all the time. Because I'm one of life's winners.</TD></TR></TABLE>
You and the thread starter both
Oh and I rev mine to 20K daily.
Old Dec 31, 2004 | 03:27 PM
v-attack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna BEN &raquo;</TD></TR><TR><TD CLASS="quote">I beg to differ!
Actually, i believe we passed 10k</TD></TR></TABLE>
Yeah mang me and baonest did it in his lsvtack in first second and third quite frequently...hahaah gotta love the JUN valvetrain
