d16a1 crank in d16a6 block?
Old Dec 29, 2004 | 03:49 PM
Cimburke23's Avatar
Default d16a1 crank in d16a6 block?
will this work? i got a free d16a1 and was gonna put the crank, rods, pistons in my crx block because the a6 spun a bearing. if anyone knows about this plz let me know. thanks
Old Dec 29, 2004 | 08:13 PM
Cimburke23's Avatar
Default Re: d16a1 crank in d16a6 block? (Cimburke23)
ehhhh????
Old Dec 30, 2004 | 05:52 AM
TurboEH2's Avatar
itll work
Old Dec 30, 2004 | 06:17 AM
86si's Avatar
Default Re: d16a1 crank in d16a6 block? (LSturboEH2)
a1 pistons will bump compression to about 12-1 with an a6 head
Old Dec 30, 2004 | 06:19 AM
Nic's Avatar
Nic
Default Re: d16a1 crank in d16a6 block? (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">a1 pistons will bump compression to about 12-1 with an a6 head</TD></TR></TABLE>
Old Dec 30, 2004 | 06:31 AM
jlicrx's Avatar
check the diameter of the A1 front snout where the crankshaft timing gear goes on and make sure it matches the A6 - some A1's have different diameter (some are 22mm and some are 24mm) than the A6 - you will need to use the crankshaft timing gear from the A6 - compression ratio with A6 head, A6 head gasket and A1 pistons = 10.78:1
Old Dec 30, 2004 | 05:09 PM
Cimburke23's Avatar
Default Re: d16a1 crank in d16a6 block? (jlicrx)
ok what about with a d16Y8 head? and Y8 headgasket??
Old Dec 31, 2004 | 12:05 AM
TurboEH2's Avatar
13.128963812527295:1 would be ur compression ratio
with a a6 block
a1 (p29) pistons
y8 head with a y8 headgasket
Old Dec 31, 2004 | 05:24 AM
The Clash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSturboEH2 &raquo;</TD></TR><TR><TD CLASS="quote">13.128963812527295:1 would be ur compression ratio</TD></TR></TABLE>
Hey man it sounds like you got some really loud rod knock there... nah that's just my detonation
Old Dec 31, 2004 | 07:02 AM
TurboEH2's Avatar
Default Re: d16a1 crank in d16a6 block? (The Clash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Clash &raquo;</TD></TR><TR><TD CLASS="quote">
Hey man it sounds like you got some really loud rod knock there... nah that's just my detonation </TD></TR></TABLE>
ummmm ok. proper tune and the right fuel would avoid that.
Old Jan 6, 2005 | 10:33 AM
staticchmbr's Avatar
we tried this same kind of transplant with a friends motor...(d16a1 crank, pistons, and rods). it woul have worked, but the timing belt was too small...then we tried a d16a1 one, and it was too big. i guess you have to find a happy medium to make it work
Old Jan 6, 2005 | 10:58 AM
TurboEH2's Avatar
Default Re: d16a1 crank in d16a6 block? (staticchmbr)
hmmmmm i would imagine the a6 belt should work. if it doesnt just use a a6 crank with the a1 rods and pistons. still the same effect since the a6 and a1 have the same displacement. he is just going for the a1 pistons for the compression and whatnot
Old Jan 6, 2005 | 01:07 PM
kid-honda's Avatar
ummmm ok. proper tune and the right fuel would avoid that. </TD></TR></TABLE>
Yea but why would he want that high of compresion, is he trying to build a race car?
Old Jan 6, 2005 | 01:11 PM
TurboEH2's Avatar
Default Re: d16a1 crank in d16a6 block? (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
Yea but why would he want that high of compresion, is he trying to build a race car?</TD></TR></TABLE>
umm this isnt his racecar. this would be his playtoy. his racecar consists of a 84mm gsr
Old Jan 7, 2005 | 10:43 AM
Cimburke23's Avatar
anyone else have any input on this?
4door93civic
Jan 3, 2014 12:35 PM
alx_90ef
Sep 29, 2009 11:35 AM
.Noah Fecks
Sep 13, 2005 07:41 PM
mrmechanic
Oct 15, 2004 05:16 PM
omahaturbocivic
Sep 28, 2003 11:05 PM
