GSR Dyno sheet needed?
Old Dec 29, 2004 | 03:21 PM
JDM_Spec's Avatar
Default GSR Dyno sheet needed?
does anyone have a pretty stock gsr with just I E on a dyno sheet with hp and tq figures. as i needing to compare with mine. im planning to put some jun stage 3 cams. why is everyone staying its bad to have stage 3???
Old Dec 29, 2004 | 03:29 PM
Moogen Powah's Avatar
Default Re: GSR Dyno sheet needed? (JDM_Spec)
I'm pretty sure that in order to run, and run efficiently with Jun stage 3 cams, that you will have to upgrade your valvetrain as well have tuning in order to get the power out of them.
Old Dec 29, 2004 | 03:35 PM
RynoDyno312's Avatar
Default Re: GSR Dyno sheet needed? (Moogen Powah)
i think anything over stage 1 needs higher compression to be effective, and an upgraded valvetrain to cope with the more agressive profile. i bet if you threw in some JDM ITR or CTR pistons along with the juns and tuned you would get some really nice gains. if you plan to keep the compression stock, you are probably better off w/ stage 1 or 2 cams.
Old Dec 29, 2004 | 03:36 PM
xprohx's Avatar
I think too much
I have a dyno plot of mines white with i/h/e. The stage 3's are usually used for the more hardcore allmotor guys. And stronger supporting mods like raising the compression ratio is needed to get the most out of them.
Old Dec 30, 2004 | 09:42 PM
JDM_Spec's Avatar
Default Re: GSR Dyno sheet needed? (xprohx)
what happens if i dont wanna upgrade the pistons and stuff. is it still good to run daily driven. will it badly effect my fuel comsuption? has any one expriened it?
Old Dec 30, 2004 | 10:13 PM
Calsonic's Avatar
Here is a dyno of my 98 GSR with CAI & cat-back exhaust.
streetlights
Jan 23, 2005 03:22 PM
RedheadRacing
Dec 24, 2004 04:04 AM
96tegsr
12
Dec 19, 2004 07:06 PM
riceball777
Apr 16, 2003 01:04 AM
