Bolt size for brake rotor (tried search already)
Old Dec 29, 2004 | 02:40 PM
kidaniel's Avatar
Default Bolt size for brake rotor (tried search already)
What size is the bolt to get the brake rotor off?
35mm?
I already got the rotor off but im replacing one of my studs for my lugs because one broke.
Thanks
Daniel
Old Dec 29, 2004 | 05:26 PM
L8ApexH22's Avatar
Default Re: Bolt size for brake rotor (kidaniel)
Well, on 4th gen, the hub nut is 36mm. 5th gen should be the same, but since I don't own one, I can't tell you for sure. If nothing else, buy a 36, try it, and if it's not the same as 4gen, take it back.
Old Dec 29, 2004 | 07:34 PM
yOnKiNaToR's Avatar
Default Re: Bolt size for brake rotor (L8ApexH22)
just in case you need to know, the rear is a different size of 32 mm
Old Dec 29, 2004 | 08:00 PM
kidaniel's Avatar
well I did try the 36..its slightly loose..
I went to Home Depot, Sears/Craftsman and no one had a 35mm.....
wth?
Guess I'll just take it to a local shop...
Any other suggestions?
Thanks
Daniel
Old Dec 30, 2004 | 07:47 PM
yOnKiNaToR's Avatar
did the 36mm socket slip off cause it was to loose? my 36 mm was a little loose too but it's so big of a socket that it didn't slip when i tried to remove the axle nuts.
if you're not happy using the 36, you could try to guess and check to find a standard size that you can tap or hammer on.
R-gonaut
Jun 5, 2011 07:27 PM
AngryJeremy
Jan 17, 2006 10:05 AM
Racermech
Mar 29, 2005 10:24 AM
Sephro
Apr 26, 2004 07:34 AM
TurboBumblBee
Jul 28, 2002 04:57 PM
