Location for TCM for 98 accord (already searched)
Old Dec 29, 2004 | 02:13 PM
eauto's Avatar
Default Location for TCM for 98 accord (already searched)
Can someone tell me exactly where the TCM is located for 98 accord 4dr sedan auto tranny 2.3l
It wold be nice with a diagram and ank knowledge on how to replace it....Thanks
Old Dec 29, 2004 | 03:43 PM
bill-71SS's Avatar
Default Re: Location for TCM for 98 accord (eauto)
it is all part of the ECM,they call it a pcm now,it is located in front of the center console
Old Dec 29, 2004 | 04:09 PM
eauto's Avatar
Default Re: Location for TCM for 98 accord (bill-71SS)
Well, where would one go buy this ?? How do I find out the part Number....any help would be appreciated.
Old Jan 11, 2005 | 06:52 PM
eauto's Avatar
ttt
Old Jan 12, 2005 | 11:28 AM
Turbowa's Avatar
Look on e-bay you can sometimes find them there or http://www.car-parts.com
Make sure you get the Vin # for the car it came out of other wise it will be no good. You will need that in order to get the imobilizer programmed.
Old Jan 12, 2005 | 02:30 PM
matt_in_sd's Avatar
The PCM is about $600 from Honda. Are you sure its bad? You can see it under the dash, behind/below the radio from the passenger side. IT mounts to the floor under all of the AC/heater crap. You might need to pull the carpet back. I would think this part is OEM only. I wouldn't trust aftermarket. If you go the used route you might need the pn of the unit to make sure you get the exact replacement.
Old Jan 12, 2005 | 07:12 PM
cmrvi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eauto &raquo;</TD></TR><TR><TD CLASS="quote">Can someone tell me exactly where the TCM is located for 98 accord 4dr sedan auto tranny 2.3l</TD></TR></TABLE>
The PCMs in late model Accords rarely go bad. Are you trying to replace it because your transmission is acting funny?
If that's the case, you'll be changing the wrong part.
'97 and up Accord transmissions are notorious for going bad.
happycamper86
Sep 25, 2013 08:38 AM
oldkid6
Jul 25, 2008 06:05 PM
a.C.r.
Apr 10, 2008 03:44 PM
jlv55
May 19, 2004 06:58 PM
