RSX rear brakes?
Old Dec 29, 2004 | 02:00 PM
PHiZ's Avatar
Default RSX rear brakes?
Is there anything special or weird to be aware of when I change the pads on my 02 RSX base? The dealer wants $275 for labor/pads/turn rotors. I'm planning on just doing the pads myself, as if it were my civic or integra...
Anything weird/special to be on the lookout for?
-PHiZ
Old Dec 29, 2004 | 02:27 PM
CBRF4i's Avatar
Default Re: RSX rear brakes? (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Is there anything special or weird to be aware of when I change the pads on my 02 RSX base? The dealer wants $275 for labor/pads/turn rotors. I'm planning on just doing the pads myself, as if it were my civic or integra...
-PHiZ</TD></TR></TABLE>
It might have the type of caliper piston that you have to turn back in. Those are a bitch to do unless you have the right tool. Im not sure but know the integra rear brakes are like that so theres only one way to find out.
Old Dec 29, 2004 | 02:32 PM
whiteDCfiver's Avatar
I just did the same thing on Sunday. **** what the dealer wants. If your rotors are good you dont need em resurfaced. If you do, go to Pep Boys, they charge 8 bucks a rotor, so not bad at all.
The front is super easy. Just two nutts and you can get to the pads. Get a screw driver and press the cylinder back in and you are good to go to reassemble.
The back requires a lil more force and wigglin around to get the caliper off. Once you do its straightforward also. Make sure you release your hand brake. To get it back in there, DO NOT TRY TO PUSH THE CYLINDER IN!! You actually turn it back in. When you look at it you will understand. Once i figured this out it was cake.
Thats about it. These cars are super easy. Goodluck.
Old Dec 29, 2004 | 02:33 PM
Default Re: RSX rear brakes? (CBRF4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBRF4i &raquo;</TD></TR><TR><TD CLASS="quote">
It might have the type of caliper piston that you have to turn back in. Those are a bitch to do unless you have the right tool. Im not sure but know the integra rear brakes are like that so theres only one way to find out.</TD></TR></TABLE>
I just turned mine back with flathead screw driver. No special tools are needed for the RSX base.
Old Dec 29, 2004 | 07:33 PM
PHiZ's Avatar
Default Re: RSX rear brakes? (whiteDCfiver)
I use one of these cheapies:
-PHiZ
Old Dec 29, 2004 | 09:33 PM
ya my buddy lent me one of those. didnt use it
Old Jan 4, 2005 | 06:52 PM
plzhitvtec's Avatar
the dealer are freaks
Old Jan 5, 2005 | 10:47 PM
PrettyLude's Avatar
If you do not have the block mentioned above, then get a pair of needle nose pliers and twist the piston back in. Shouldn't take more than a minute or two.
Old Jan 7, 2005 | 07:18 AM
CivicEM's Avatar
DIY and get some Brembo's
Old Jan 8, 2005 | 08:59 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: RSX rear brakes? (CivicEM)
I went to Honda once for a 96 Civic rear drums. The ******* says 150$ to TURN (not replace) the rear DRUMS. I found 40$ online for new ones, and napa will do each drum for 13$ a piece to turn em.
In other words, screw the dealership. Search for the rear calipers, it takes a wrench attachment that isnt required. the piston sort of spirals in, which with a sort of wide *** flathead screwdriver (some use the edge of the brake pad) to get it in. Spend 65$ for a Helms manual. These are really not too hard to do.
Turtle_FA5
Northern California (Sales)
Jul 29, 2012 01:58 PM
92integraVTECgsr
Mar 4, 2009 06:45 PM
S2Kricer
Jul 23, 2006 07:24 AM
rated_r
Jan 15, 2004 07:23 PM
drunknbass
Dec 14, 2003 10:14 AM
