Bare wire coming out of RCA wires?
I recently bought a couple pairs of Monster Cable XLN rca cables, but on one end of each set, there are a couple bare wires coming out of the casing. I am stumped what these are for...cd changer maybe? anyone know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drkblue_civic »</TD></TR><TR><TD CLASS="quote">i believe it is intended to be used as the remote line </TD></TR></TABLE> This is what most RCA's with a insulated wire running down the middle is for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn »</TD></TR><TR><TD CLASS="quote">its a ground wire that runs through it. but u dont need to ground it all. i just electrical taped it off, no biggie.</TD></TR></TABLE>
Is correct this is extra shielding to protect against noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote"> This is what most RCA's with a insulated wire running down the middle is for.
Is correct this is extra shielding to protect against noise.</TD></TR></TABLE> Ditto that..... and if its only at one end of the RCAs that will be the down stream side, [ amp or processor]
94
94
According to Steve Eckblat (sp) sorry Steve..and others who posted on here
this is the audio ground. Its allows better isolation of noise by not giving the
signal a return point.
have fun
have fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by audioroach »</TD></TR><TR><TD CLASS="quote">According to Steve Eckblat (sp) sorry Steve..and others who posted on here
have fun
</TD></TR></TABLE>Ground is a return path. By tying two components together the idea is that the two grounds will be at the same potential. So you would ground one end to the radio and the other end to the amplifier. Noise comes from having two different potentials (not all noise), if one ground is slightly higher or lower than the other ground then current will flow.
have fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">Ground is a return path. By tying two components together the idea is that the two grounds will be at the same potential. So you would ground one end to the radio and the other end to the amplifier. Noise comes from having two different potentials (not all noise), if one ground is slightly higher or lower than the other ground then current will flow.</TD></TR></TABLE>I think, on this RCA the the pigtail is only at one end of the RCAs and if that is the case, it will be the second, [ outside] layer of shield, it will be isolated from the sig. ground, [inside shield] at the top end, [HU] but would allow you to ground it at the down stream side, so as audioroachs quote
have fun
10 + years ago this was a must when installing bigger systems , HU then processers, then x-overs then the amps, we would have to custom make the RCAs, we would use a double shielded interconnect , isolate the outside shield at the HU, then connect the outside shield to the sig, ground, [inside shield or, in the case of monster wire, the sig. ground wire] on all the rest of the RCA ends, [up and down stream of all componants, ending at the amp] this worked because any "noies" picked up by the outside shield had no path into HU, [outside shield isolated] could only "travel" down stream to the common grounds of the RCAs sig. ground to be "dumped" into the cars chassis.
I also have to agree with nsxxtreme......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme »</TD></TR><TR><TD CLASS="quote">Ground is a return path. By tying two components together the idea is that the two grounds will be at the same potential. So you would ground one end to the radio and the other end to the amplifier. Noise comes from having two different potentials (not all noise), if one ground is slightly higher or lower than the other ground then current will flow.</TD></TR></TABLE> When there is a pigtail at both ends of the RCAs and that wire is not connected to the shields in any way, connecting that wire to the HU and then the amp, or processer and then from processer to amp is a good way to get rid of noies, [ and as he says, not all noies].
I always use that wire for "ground loop", never for amp trigger, and if the RCAs do not have this wire, then I will run one along with the amp trigger, just in case, although not needed most of the time, if there is noies, then connecting this wire at the amp, [already connected at the HU] will get rid of noies, or let me know ,very quickly, that the problem is not because of a ground loop between the HU and processer/amp, saveing me time. And time saved, is good time.
94
have fun
94
.water
Audio / Security / Video
24
Dec 18, 2005 12:23 AM
bassisliffe
14
Jul 17, 2004 05:28 PM
