GT35R oil pressure...
Old Dec 29, 2004 | 09:58 AM
1Bar GSR's Avatar
Default GT35R oil pressure...
I was told that if you are running a GT35r you have to have lower oil pressure then just taping it from the back of the block? Someone said to put a nitrous jet in the feed like to lessen it... Can anyone help me on this of what to do and what oil pressure I need to be at?
Old Dec 29, 2004 | 10:44 AM
b18bturbo's Avatar
Default Re: GT35R oil pressure... (1Bar GSR)
you can either do that or go to atpturbo.com and get he oil feed restrictor.
Old Dec 29, 2004 | 12:00 PM
DIRep972's Avatar
Smarter than you
From what I've read, the GT series come w/ an oil restrictor built into the CHRA already, so you should just run a -3 line like normal.
If someone was willing to do a test, by putting an oil pressure gauge somehow tapped into the housing, then we could figure out if we need extra restrictors or not for sure.
Garrett reccomends that you have about 12psi of oil pressure into the turbo at idle, and no more then 40psi at WOT. If it is more then that you will get blow by past the seals.
Old Dec 29, 2004 | 02:00 PM
Turbo-charged's Avatar
Default Re: GT35R oil pressure... (DIRep972)
my 35r straight from precision came with a restrictor.
Old Dec 29, 2004 | 02:25 PM
11psiTurboSI's Avatar
Default Re: GT35R oil pressure... (Turbo-charged)
Did you guys have to run the coolant lines to the turbo?
Old Dec 29, 2004 | 06:47 PM
TheShodan's Avatar
Moderator
Default Re: GT35R oil pressure... (11psiTurboSI)
For the GT35R, it is very advisable to run the coolant lines to the turbo. This is actually advisable for any steel ball-bearing CHRA turbo. Because the turbo bearings are not a "floater" design, in which they depend upon a "layer" of oil to float the bearing like most turbos, a restrictor of .0008mm is needed in order to restrict oil to only 22psi of pressure, on a constant basis. That is why the small apeture. Any more, and you WILL destroy the CHRA in which it would cost just as much to rebuild the turbo as it would be to get a new one.
On steel Ball-bearing turbos, they do just that; run on steel bearings that are lubricatedby some oil, and cooled by the water lines so as not to overheat itself and ruin the CHRA. The Steel bearings have a distinctive noise, (which we love) but are a bit more delicate when it comes to the oil pressure.
Precision BB provide a restictor, ATP Turbo has a kit that can be used.
Old Dec 29, 2004 | 06:54 PM
t04ecvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">From what I've read, the GT series come w/ an oil restrictor built into the CHRA already, so you should just run a -3 line like normal.
Garrett reccomends that you have about 12psi of oil pressure into the turbo at idle, and no more then 40psi at WOT. If it is more then that you will get blow by past the seals. </TD></TR></TABLE>
Yup, see man, I wouldn't lie to ya!
Old Dec 29, 2004 | 07:21 PM
91TegLS's Avatar
Default Re: GT35R oil pressure... (TheShodan)
.0008 mm? I know you're very knowledgeable about turbos, but that's an insanely small restrictor, you'd be lucky to even see the hole. I'm confused.
Old Dec 29, 2004 | 07:27 PM
1Bar GSR's Avatar
Default Re: GT35R oil pressure... (91TegLS)
So only the precisions come with a restrictor already in? I will look into the restictor from atpturbo.com but do the GT series dont? I wanna make sure before I go buy the restrictor?
Old Dec 29, 2004 | 07:28 PM
t04ecvc's Avatar
Maybe he means .008 ".
Old Dec 29, 2004 | 07:29 PM
t04ecvc's Avatar
Its a precision turbo, with garrett housings and precision inards I believe.
Old Dec 29, 2004 | 07:52 PM
91TegLS's Avatar
Default Re: GT35R oil pressure... (t04ecvc)
My GT28R already came with a restrctor on the oil inlet hole. Do I still need to get a restrictor from ATP?
Old Dec 29, 2004 | 07:59 PM
PeakBoost's Avatar
B*A*N*N*E*D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04ecvc &raquo;</TD></TR><TR><TD CLASS="quote">Its a precision turbo, with garrett housings and precision inards I believe.</TD></TR></TABLE>
its the other way around. Garrett cartridge.
all Garrett GT cartridges have a built in oil restrictor even ours and ATP's
we have seen great results when using a .060" restrictor on anything from 60-110psi and a .050" above 110psi(rotary mostly).
i wouldnt recommend using the above mentioned .0008mm restrictor (a human hair is appx .04 mm at best) as this will limit the volume of oil to the point of starvation.
hope this helps
Old Dec 29, 2004 | 08:58 PM
Muckman's Avatar
Moderator in Chief
Did you pull that number out of your *** or what?
Old Dec 29, 2004 | 09:10 PM
1Bar GSR's Avatar
Default Re: GT35R oil pressure... (Muckman)
BUMP so... restictor built in or buy one from atpturbo.com AND WHAT size
Old Dec 30, 2004 | 08:11 AM
t04ecvc's Avatar
Default Re: GT35R oil pressure... (CHEAPTURBOdotCOM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEAPTURBOdotCOM &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, lol, that makes alot more sense.
Old Dec 30, 2004 | 08:22 AM
1Bar GSR's Avatar
http://www.atpturbo.com/Mercha...=GTBB
Im guessing thats what were talking about here?
Old Dec 30, 2004 | 09:09 AM
TheShodan's Avatar
Moderator
hope this helps</TD></TR></TABLE>
Sorry about that.... typeed too mannnny 000000 I meant .080. But it's true, .050-.070 is fine. Some of the precisions come with a restrictor KIT, but it is an additional cost..
such animosity for a typo!!
Old Dec 30, 2004 | 10:07 AM
1Bar GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
Ok thats what im looking for thank you!
Old Dec 31, 2004 | 06:01 PM
91TegLS's Avatar
Okay, so my GT28R came looking like this
http://70.105.206.36:870/oilfeed.JPG &lt;-- If pic goes retarded
Do I still need a restrictor or is that it? I really don't want to go blowing the seals on a brand new turbo. Thanks.
-Dave
Old Dec 31, 2004 | 07:30 PM
5thgencivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">http://www.atpturbo.com/Mercha...=GTBB
Im guessing thats what were talking about here?</TD></TR></TABLE>
That's what I'm running on my 28R
Old Dec 31, 2004 | 10:08 PM
12secDailydriver's Avatar
Default Re: GT35R oil pressure... (5thgencivic)
You need to put a restrictor on that GT28R.......I talked to Precision turbo,and they said yu have to have atleast 1/4" id coolant lines running to the CHRA so the CHRA will live.Precision includes the restrictor,ATP does not,you have to order with the turbo and don't foprget to order the GTR drain line flange as well!I love my GT30R,best turbo I ever had!
Old Dec 31, 2004 | 10:10 PM
Default Re: GT35R oil pressure... (12secDailydriver)
BTW,cheapturbo guy,why do you guys only give a 90 day warranty??Turbonetics and Precision and ITS give 1 year full warranty.....you guys offer a "rebuilders" 90 day warranty.Some guys don't even install their turbo within 90 days.....
If you guys offered a decent warranty,you will sell more turbos!
Old Jan 1, 2005 | 06:19 AM
91TegLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secDailydriver &raquo;</TD></TR><TR><TD CLASS="quote">You need to put a restrictor on that GT28R.......I talked to Precision turbo,and they said yu have to have atleast 1/4" id coolant lines running to the CHRA so the CHRA will live.Precision includes the restrictor,ATP does not,you have to order with the turbo and don't foprget to order the GTR drain line flange as well!I love my GT30R,best turbo I ever had! </TD></TR></TABLE>
Thank you sir. That's what I wanted to know.
-Dave
Old Jan 1, 2005 | 03:16 PM
Turbocivic94's Avatar
Does anyone has coolent line setup?
I have GT35R and I want to know how people run their coolent lines. The atp restrictor seems small.
