Brand new omnipower coilovers, yet they bounce?
Old Dec 29, 2004 | 09:46 AM
khmboostedeh2's Avatar
Default Brand new omnipower coilovers, yet they bounce?
hey.. heres the situation
-brand new rear omni power coilovers.
-they bounce like a champ.
the settings i have:
-ive compressed teh spring as much as i could, which isnt more than like CM because the whole unit begins to spin.
-from the bottom of the spring damper plate to the end of the threads is about 3-4inches.
what kinda changes should be made to the settings on the coilover? this is my first time using coilovers, and yes of course ive serached.
Old Dec 29, 2004 | 10:41 AM
Denny Crane's Avatar
Default Re: Brand new omnipower coilovers, yet they bounce? (Jeterkm02)
1. The damper doesn't match the spring rate, and/or
2. The damper is bottoming out on the limiter, and/or
3. The coil is binding / coil-stacking , and/or
4. Ride height set too low causing #2 and / or #3 above, and/or
5. Wrong parts fitted
Old Dec 29, 2004 | 10:50 AM
Default Re: Brand new omnipower coilovers, yet they bounce? (Denny Crane)
they're brand new though. these mismatches, could they happen during the manufacturing process? they're for 92-00 civics.
ive got about an inch and a half between the (stock) wheel and wheelwell.
Old Dec 29, 2004 | 11:00 AM
PreStaged12s's Avatar
Which ones did you buy because OMNI just came out with some coilovers that are drag race coilovers with an 18k rear spring rate and that is pretty damn stiff, like most street applications have rear spring rates of only 8k or 10k, so that could definitely have to do with the bouncing.
Old Dec 29, 2004 | 11:35 AM
Default Re: Brand new omnipower coilovers, yet they bounce? (PreStaged12s)
hmmm u know i have no clue. any way to tell on the suspension itself? i bought these new off ebay. they were minty when i got them and still wrapped in the original plastic.
Old Dec 29, 2004 | 11:41 AM
Solracer's Avatar
Whats on the Front of the caR?
Old Dec 29, 2004 | 11:47 AM
Default Re: Brand new omnipower coilovers, yet they bounce? (Solracer)
crappy *** sprint springs/shocks.
Old Dec 29, 2004 | 02:05 PM
Depends, I think on the OMNI its a red spring and all the info on the spring is in white writing, its like 5 or 6 numbers
Old Dec 29, 2004 | 02:12 PM
ill take pictures tommarrow. till then i must thank u for ur help.
Old Jan 12, 2005 | 06:24 AM
mraudio13's Avatar
I would like to know some more info on this too, Mine are bouncy when driving at higway speeds. It drives me crazy!!
Old Jan 12, 2005 | 05:17 PM
Default Re: Brand new omnipower coilovers, yet they bounce? (mraudio13)
that was my problem.
the # on my springs are:
0178.63.5.018
and they turned out to be drag coilovers used on Titan Motorsports cars.
did you preload yours? i just read about ti today on another thread.
Old Jan 17, 2005 | 04:42 AM
mraudio13's Avatar
Ok I preloaded both front and back and it rides soooo much better. These def need to be preloaded in front and back...Matt
Old Jan 17, 2005 | 09:45 PM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 &raquo;</TD></TR><TR><TD CLASS="quote">that was my problem.
0178.63.5.018
did you preload yours? i just read about ti today on another thread.</TD></TR></TABLE>
those are drag coilovers with a 800lb spring rate....
http://www.omnipowerusa.com/Pr...s.asp
Fast510
Suspension & Brakes
May 17, 2014 05:52 PM
EG6 Love
Suspension & Brakes
Jul 23, 2008 10:36 PM
Aphrodavid
Nov 25, 2002 12:45 PM
Lt. Dan
Mar 5, 2002 06:21 PM
allmotorEG-SI
Oct 16, 2001 05:41 PM
