B20B conrod?same height with after market conrod like eagle and crower?
r they same height?after market just make for stronger?
anyway,i'm looking for 14mm valve lift 85mm high compression piston?whick piston should i get.cos i have a camshaft with 12.5 valve lift with 304dur.****..it valve to piston problem even i skin down valve pocket problem.maybe the conrod 2 long or the piston is nop support.Thanx!any idea?it valve hit piston just when vtec kick in?i st the camshaft many time it still hit!wat the prolem?
