anyone w/ fastbrakes 11" spec R upgrade?
Old Dec 29, 2004 | 08:35 AM
1whitedc2's Avatar
Default anyone w/ fastbrakes 11" spec R upgrade?
i am interested in the 11" spec R brake upgrade from fastbrakes, which would be composed of ITR calipers and 11" rotors, supposedly the caliper mounting bracket would need to be trimmed, the dust shield would need to be trimmed and bent back, i wonder if anyone had done the install and how do they fit? how about performance? do they haul down the integra pretty good?
Old Dec 29, 2004 | 08:47 AM
Dan GSR's Avatar
Default Re: anyone w/ fastbrakes 11" spec R upgrade? (1whitedc2)
https://honda-tech.com/zerothread?id=734560
for street driving, it made no noticeable difference
on track, the car feels great
Old Dec 29, 2004 | 09:23 AM
1whitedc2's Avatar
Default Re: anyone w/ fastbrakes 11" spec R upgrade? (Dan GSR)
i was mainly interested for street driving, so it made no apparent difference huh? i was hoping a better pedal feel...
i've done a big brake upgrade on my 90 eclipse GST from single piston to dual piston and that made a huge difference in terms of pedal feel and fade resistance, i guess either the GSR oem brakes are good enough and the ITR doesn't make that big of a difference to be felt on the street...
Old Dec 29, 2004 | 09:31 AM
Dan GSR's Avatar
the gsr and itr have same diamater piston
for you, for the best street performance, i'd reccomend some cobalt friction GT-Sports brake pads, along with some new blank rotors
maybe some steel braided brake lines,
and a complete brake flush
break them in properly, and you'll be very happy
Old Dec 29, 2004 | 10:06 AM
1whitedc2's Avatar
i am currently running on hawk pads w/ powerslot rotors, along w/ goodridge lines, don't feel a big difference compared to oem, and i have aftermarket suspension w/ toyo T1-s tires too...
Old Dec 29, 2004 | 10:56 AM
Dan GSR's Avatar
Default Re: (1whitedc2)
which hawk pads? hps? hp+ ?
you may just need to flush the fluid,
Old Sep 28, 2005 | 04:09 AM
Stinkycheezmonky's Avatar
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1whitedc2 &raquo;</TD></TR><TR><TD CLASS="quote">i am currently running on hawk pads w/ powerslot rotors, along w/ goodridge lines, don't feel a big difference compared to oem, and i have aftermarket suspension w/ toyo T1-s tires too...</TD></TR></TABLE>
Regardless of the suspension (as that has no effect on how the brakes will feel), if those Hawk pads aren't the worthless HPS pads you should feel a significant difference if you put everything on and bled the system correctly.
SpoonPL2
Suspension & Brakes
Sep 4, 2008 02:43 PM
Stinkycheezmonky
10
Oct 4, 2005 04:22 AM
Understeer
Aug 25, 2003 04:09 AM
geminis2k
Dec 22, 2002 06:04 PM
slow_civic
Dec 30, 2001 10:56 PM
